SOURCE: AE 740 types different characters than typed on keyboard
make sure your printwheel is latched securely, turn off t/w, press and hold the margin release button while turning power on to do a reset/self-test. if characters are not right on self test, then you might have a problem with either the carriage or main board.
hth,
razors
SOURCE: keyboard on gateway W323-UI1 does not work
yes the keyboard can be replaced on laptops and notebooks.
SOURCE: my keyboard doesn't work, sometimes it does and
If it works fine in Safe Mode, I would bet you have an issue related to a virus or malware.
Run a scan in Safe Mode and make sure your computer is virus free.
If it didn't work okay in Safe Mode, I would've said you have a bad keypad and recommend replacing it.
SOURCE: volume down button doesn't work
hi, make sure the face pins are clean; try resetting the unit; check to see if the feel of the down switch is the same as the up switch....if not then your down switch is faulty and needs to be replaced. confirm the volume down operation by using the remote control (if available), if it works then your problem lies with the switch or a broken connection between the switch pins and the face control circuit. cheers.
SOURCE: how to find mac address for huawei 8655-1
go to settings/about phone(status and there is wifi mac adress!
