Kodak EASYSHARE M1063 Digital Camera Logo
Posted on Aug 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kodak Easyshare M1063. Picture transfer.
Won't transfer pictures from camera - device is recognised. Appears pictures (3) ahve transfeerd from internal memory, but not from memory scandisk in camera. Many Thanks.
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Kodak Master 102,366 Answers
  • Posted on Nov 22, 2014
Kodak Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10442795
Points
622693
Try NOT connecting your camera to your computer.
The best way to transfer pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
Organize edit and share your photos
5 Related Answers
Anonymous
  • 34 Answers
  • Posted on May 01, 2009
SOURCE: driver of camera kodak easyshare m1063
Hello here is a direct link to your site to download your driver. Just select your operating system and click download.
http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=13051&product=EKN035308
Hope this helps
-Chris
Vitally Alcher
  • 1645 Answers
  • Posted on Jun 02, 2009
SOURCE: Kodak 1063 Not transferring all Pictures
Charge battery full
Then TAG the pictures with as many tags possible. Up to 10
Make new tags.
then Protect and Favourite the pictures videos etc.
Then transfer again to your "file" on computer. and check for the numbers are continius. Delete the dupl;icates that show with the 2 zeros "00"
Vitally
Anonymous
  • 8 Answers
  • Posted on Aug 15, 2009
SOURCE: My Kodak Easyshare M1063 won't turn on
Try cleaning the contacts from the battery and the battery compartment of the camera. I had the same problem and this fixed it, it seems to be a common problem.
  • 102366 Answers
  • Posted on May 13, 2010
SOURCE: How do I transfer pictures in the Internal memory
First, make sure you have a card installed. Press the Review button, then the Menu button. Use up/down to highlight Copy, then press OK. Use up/down to highlight an option, then press OK.
  • 102366 Answers
  • Posted on Jun 30, 2010
SOURCE: How do I transfer all pictures from the "internal
First, make sure there is a card installed in the camera. Set the camera's picture storage location to the internal memory. Press the Review button, then press the Menu button. Press up/down to highlight Copy, then press the OK button. Press up/down to highlight an option, and press OK.
To set the camera's picture storage location, press the Menu button. Press up/down to select Image Storage. Select Internal Memory and press OK.
My m1063 Kodak camera will transfer most of the pictures to my computer. A few pictures will not transfer. Is there something I can do to correct this problem?
Do the pics that will not transfer have the same numbers as ones already on your computer? If so, the computer thinks you already downloaded them.
1helpful
When transfering pictures from camera to PC EasyShare will not transfer some pictures. "picture already exists" in My Collection. These are all new pictures taken with blank memory card. This occurs even...
Scrap the camera! Kodak hasn't and won't address the problem. Most picture download software won't recognize the camera. The only solution is to remove the memory card from the camera, put it in USB adapter and treat it like a flash drive. Cumbersome. Awkward. Stupid. After you scrap the ****, tell your friends so they don't make the mistake of buying a Kodak.
How do i upload duplicate pictures. it keeps
EasyShare software checks the pictures and videos being transferred from your device with those already in your collection. The software will not transfer duplicate pictures and videos. For assistance regarding duplicate picture call Kodak support line 1 800 235 6325 (23KODAK) Option 12 on the voice prompt select 1 or software support.
4helpful
3answers
Pink colored pictures from my digital camera
For this problem try doing the ff:
  • transfer the photos to the computer
  • set the camera in auto mode
  • take a picture
  • if the picture is still pink and blurry even after transferring to your computer
  • call the tech number 18002356325
Thanks
Byron
Kodak Easy Share program blocks transfer of photos with the same number, as used before, though I am using different album. Message: "Pictures are already in collection and not transferred again". How to...
You probably can't turn it off. Download the pics from one of the cameras to a folder you create on your desktop and if the numbers are the same, simply rename them.
1helpful
Charge battery full
Make new tags.
Vitally
67helpful
7answers
Trouble uploading "duplicate" pictures
I've just found a fix for this problem after fighting it myself for a week. Don't use the transfer window that Easyshare gives you when you connect your camera (or which is also available under the tools/cameras/viewers dropdown menu).
Cancel this window if it comes up. Then select "add pictures" from the file dropdown menu (as if you were going to add pictures from your hard-drive to the easyshare gallery). The camera will appear in the folder list. Open the m1063 folder, select the pictures you want (or select all) then click the "add pictures" button.
-Neil
Can't transfer photos from computer to digital frame
Copying pictures from EasyShare software:
1. Install EasyShare software (free download at www.kodak.com/go/sw)
2. Connect the USB cable.
3. On your computer, open EasyShare software. Select the pictures in My Collection and drag them into the Picture tray.
4. In the menu bar, select File and then Copy to the Kodak Drive letter.
The picture frame appears as removable drives—one drive for each connected picture source in the frame, in this order: internal memory, memory cards, and USB devices.
5. Select the frame source to which you are copying.
6. Select Best for Digital Picture Frame to reduce the resolution of the pictures you are copying. Full resolution is unnecessary and quickly fills up the frame's memory.
7. Click Copy. Pictures are copied to your frame.
8. Unplug the USB cable and on the frame check the pictures that were just copied.
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
