SOURCE: on weedeater blower and vac gas line is broke from
Yes if your asking about the fuel line yes it hooks to the filter out thru the wall of the gas tank straight into the carb. if it broke out side the tank you can try a smaller plastic hose to stick inside to reconnect the two parts. if it broke inside the tank try to replace as one hose.
SOURCE: weedeater leaf blower FL1500
Check the fuel lines for cracks/breaks. If they are o.k., then:
Youwill need to disassemble the carburetor and spray withcarb.cleaner.Make sure the small screen is free of debris. (Should beable to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
SOURCE: I have spark compression gas but my weedeater bower/vac 1650 wont start. What should i check for ?
Try a new spark plug. A bad spark plug will spark in the open but not under compression.
