Question about Life Fitness Exercise & Fitness
I have a life fitness x5- when I select a workout and press the enter button - it states "wait" and then resets.never being able to start a program. Any thoughts
SOURCE:
  • 6 Answers
SOURCE: Screen goes blank
Maybe the setting of your video display was change to higher setting, and your screen cannot handle the said setting.
When a "safe mode" message appears during opeing, select that options, then at the desktop right click your mouse, chose properties, then setting, then change the screen resolution to lower range.
Posted on Dec 05, 2007
SOURCE: Nuvi 350 won't accept addresses -
I called garmin and they walked me through the solution - select the NA map version under settings and restart.
Posted on Oct 02, 2008
sharcnet
  • 2130 Answers
SOURCE: unable to enter new address
Please see this link to:
http://www.sharc.net/discus/messages/6/75.html?1235511886
If this resolves your issue, please rate me as Fixya.
Thanks,
- Jim
Posted on Mar 02, 2009
greenspan
  • 1734 Answers
SOURCE: Once I program in my workout and it says to start
Check your manual. If you don´t have one, they can get you virtually any Reebok manual.
Posted on Jul 23, 2009
  • 3 Answers
SOURCE: reset lamp life on mitsubishi SL1U projector
Press the < and > and power buttons on the projector all at the same time.
Posted on Oct 22, 2009
I have a Stepmill 7000 pt. I have a terrible time trying to start a workout program like quick start, manual, fat burner, etc. I have to push the program button multiple times to start the program.
It sounds like you may have a faulty keypad. The following link will take you to this item. Stairmaster Stepper 7000PT Stepmill Parts Transmission SPORTSMITH net You might also be looking at a faulty ground or insufficient power coming from your power supply. Check this out put with a multimeter. You should be getting between 12-19 volts DC.
Dec 05, 2017 | Stairmaster Stepmill 7000 Pt
I have a life fitness 9500hr treadmill. I cannot get any movement from the belt at all. I type in all the workout details and it says 'enjoy your workout', only the workout does come. There is a long pause...
More than likely, you will need to replace either your console or motor control board. They only way to tell is to test to the voltage and determine if there is a disconnect between one or the other. If you are in the united states, it is best to call a fitness equipment repair company. If you are in Georgia, visit www.AtlantaFitnessRepair.com
Dec 12, 2017 | Exercise & Fitness
User not detected on belt
this occurs when the user is not walking on the belt to disable this feature you must press the option "select workouts" in the lower right corner press life fitness logo, when the menu appears in maintenance mode select the option user sensor and desactivate
then exit the menu and ready
Jan 21, 2014 | Life Fitness 95Ti Treadmill 95 Ti
The term immobilize is on the display panel and I want to start it up. How do I get it going again?
When necessary to immobilize the treadmill, set display to read SELECT A WORKOUT. (Press the STOP Key
twice if not already there). Then hold down the SPEED DOWN Key and press the STOP Key. The treadmill
now displays IMMOBILIZED. In this state, the treadmill cannot be operated. The main motor and incline are
disabled. The treadmill will remain in this state across resets, power cycles, etc. To restore normal operation,
repeat the same key sequence: hold down the SPEED DOWN Key and press the STOP Key. The treadmill will
display SELECT A WORKOUT again.
Apr 11, 2013 | Life Fitness T5-0 Treadmill Fitness...
The term immobilize is on the display panel, how do I get rid of that and get it working again
What's your problem?I have a life fitness 9100 hr I have a problem how do I clear the message waxer tank empty?
see this step and fix it. God bless you
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or move on to the next step.
  • 2 Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
  • 3 Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
  • 4 Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.
  • Oct 15, 2012 | Life Fitness 9100 Next Generation...
    I can't find the reset button on my life fitness T7-0.
    The pan has to be removed to get to the reset button on mine, I have the same model
    If you need further help, I’m available over the phone at https://www.6ya.com/expert/michael_2094e122cc46f24c
    Sep 27, 2017 | Life Fitness T70 Treadmill
    The screen reads "unit immobilized
    To Get to the manager and check for disabled items.
    To enter the Systems Options Menu:
    1. Press SELECT WORKOUT.
    2. Touch the Life Fitness logo in the upper right hand corner of the screen three consecutive times
    go to configuration
    Configuration
    Allows authorized personnel to access all configurable settings of the unit. Configurations which should only be changed by qualified technicians are password protected.
    Manager Vivo/Network
    Manufacturer , Create Your Own
    Media Center , Clock
    Custom Workouts
    Touch Screen Configuration
    Export / Import Settings
    The console manual will show you all the default values .
    https://www.lftechsupport.com/c/document_library/get_file?p_l_id=27605&folderId=483177&name=DLFE-28306.pdf
    Feb 01, 2011 | Life Fitness 95Te Treadmill
    How to reset a brother mcf-7420 printer?
    1. Start the BRAdmin Professional utility, by clicking Start => All Programs or Programs => Brother Administrator Utilities => Brother BRAdmin Professional Utilities => BRAdmin Professional.
    2. From the main BRAdmin screen double click the appropriate printer.
    3. Enter the print server password (The default password is "access").
    4. Click the Control tab
    5. Click the Restore Factory Defaults button
    6. Click the OK button when you have read the warning message.
    7. The print server will then reset back to its default values.
    1. Start the BRAdmin Professional utility, by clicking Start => All Programs or Programs => Brother Administrator Utilities => Brother BRAdmin Professional 3 => BRAdmin Professional 3.
    2. From the main BRAdmin screen double click the appropriate machine.
    4. Click Network Configuration tab, Control Panel and select Set Default.
    5. Click on Submit button.
    6. The print server will then reset back to its default values.
    Via a web browser
    Because web based management requires the TCP/IP protocol for communication, any reset option you see when managing the machine with a web browser, will not reset the IP address details that are set. If you wish to totally reset all the print server parameters we recommend you reset the print server by using the BRAdmin application.
    To reset the print server (excluding TCP/IP parameters) follow these steps:
    1. Connect to the printer using a web browser.
    2. Click Network Configuration.
    3. Enter the print server password (the print server password is detailed in the user guide for the print server) if it's applicable.
    4. Click the Set Default link or Reset Print Server.
    Via the control panel (only for network ready models)
    1. Make sure the machine is not operating, then disconnect all the cables from the machine (except power cable).
    2. Press the Menu or Menu/Set key on the control panel.
    3. Press up or down navigation key to select LAN or Network and press Set, Menu/Set or OK.
    4. Press up or down navigation key to select Factory Reset or Network Reset and press Set, Menu/Set or OK.
    5. Select Reset.
    6. Select Yes.
    7. The machine will re-start, re-connect cables once this is complete. please rate it
    Nov 29, 2010 | Brother MFC-7420 Printer
    I have a life fitness treadmill and put new wax in the blader how do i start the machine and put wax on the belt?
    you will need to go into service menu by pressing and holding the pause button then pressing the clear button twice , continue holding the pause until the service menu appears. then use the arrow up and select maintenance press enter then either use arrow up or down scroll and say refill waxer system or replacing wax bag press enter, this will reset upper console. Upon completion of this the go back into the diagnostic menu select system test press enter scroll up or down to waxer manual mode hit quick start and that will fire up the wax pump and your done
    Apr 12, 2010 | Life Fitness 9100 Next Generation...
    Exercise & Fitness Logo
    67 people viewed this question
    Top Life Fitness Exercise & Fitness Experts
    Vincent_G
    Vincent_G
    Craig Butler
    Craig Butler
    Android Man
    Android Man
    Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
