Question about Video Cameras
Ihave safeguard modeverrorcode 06 - Video Cameras
2 Suggested Answers
SOURCE:
philipp
  • 217 Answers
SOURCE: safeguard mode error 06
Defective mechanism,
a stucked mechanism is
present. camcorders are
smart. it can detect error
and shut down itself for
safety. earlier models
domino the defect if
the user is not quick
enough to react when
something goes wrong with
the camera. You need
professional service to
fix it.
Posted on Dec 13, 2007
How do I get a jvc camcorder out of safeguard mode. Error 06
Step 1 Look at the camcorder's display to identify if it is in Safeguard Mode. If its display indicates an error number of E01 to E06, your camcorder is in Safeguard Mode.
Step 2 Disconnect your camcorder from its power source and remove its battery by sliding the latch forward and sliding the battery down while pulling it away from the camera's body. Wait at least two minutes before continuing.
Step 3 Remove the camera's cassette by pressing the "Eject" button, waiting for the cassette door to open, and lifting it out of the tape bay. This step is only necessary if the camera indicates the E03 or E04 error code or it tells you to eject and reinsert the tape.
Step 4 Replace the camera's battery, power connection and cassette, and turn the camera on.
Sep 04, 2015 | JVC Video Cameras
HELP PLEASE
What model JVC camera?
Jun 16, 2013 | JVC Video Cameras
I HAVE A JVC GR-D820EK MINI DV VIDEO CAMERA AND IT IS DISPLAYING UNIT IN SAFEGUARD MODE 06, I HAVE TRIED REMOVING BATTERY AND DC PLUG BUT NOTHING HAPPENS IT WILL NOT WORK ON EITHER PLAY OR RECORD, PLEASE...
i HAVE A JVC GR-D820EK MINI DV AND IT IS DISPLAYING UNIT IN SAFEGUARD MODE 06, I HAVE TRIED REMOVING BATTERY AND DC PLUG BUT NOTHING HAPPENS IT WILL NOT WORK ON EITHER PLAY OR RECORD, PLEASE COULD YOU ADVISE
Feb 11, 2011 | JVC GR-D775, GR-D790, GR-D796, GR-D820EK,...
IHAVE REH 241 RINNAI HEATER THAT WAS GOING OUT AFTER A AN HOUR OR SO I CHANGED OVER THE OVER TEMP AND THERMOCOUPLE COMBINATION WORKED GREAT FOR ABOUT A WEEK NOW HAS SAME PROBLEM AGAIN
Hows the pilot flame looking, is it nice and blue. The pilot flame on some of these units has was called oxygen depletion safeguards. It's to shut the unit down if the oxygen level in the room gets low. In practice it means the pilot light has to be perfect. I always like to recommend getting these units serviced regularily.
Jul 01, 2010 | Heating & Cooling
GR-290EK IN SAFEGUARD MODE 06 . ADVISES REMOVAL OF THE TAPE BUT WONT EJECT TAPE.
Your capstan motor has a problem, could be stucked-up or sensor fails. No capstan pulse detected.You may check capstan supply and drive as well. Good Luck
Mar 11, 2010 | JVC Video Cameras
Gr-dvl-520u trying to record or playback tape it goes into safeguard mode within 5 seconds. alternatly pressing play and still every 3 seconds advanced the playback without it going into safeguard mod
According to http://www.techlore.com/article/10974/JVC-Camcorder-Stuck-in-Safe-Mode/,
"JVC notes that you are also given a malfunction code when the unit is placed into safeguard. If it displays code 01, 02, or 06 you should remove
the battery and powersupply and wait for a while. Code 03 and 04 indicate that you should eject and reinsert the tape.
If neither of these solutions work, your only alternative is to bring it to a shop or send it to JVC for diagnosis or repair. Unfortunately, there is no other way to clear the condition."
If you are getting E03 or E04 errors on every tape you try, it sounds like a servicing is required.
Apr 17, 2009 | JVC Cybercam GR-DV500US Mini DV Digital...
I am recieving error E04 "safeguard mode"
An excerpt from http://www.techlore.com/article/10974/JVC-Camcorder-Stuck-in-Safe-Mode/:
According to this, E04 denotes a problem with the recording media or the mechanical bits that deal with the tape. Hopefully trying another tape helps.
Mar 09, 2009 | JVC 580136 Camcorder
Safeguard mode error 06
fix it.
Dec 12, 2007 | JVC GR-D240 Mini DV Digital Camcorder
Camcorder
Defective mechanism, 06 error states that a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera.
Aug 31, 2007 | JVC 580136 Camcorder
Video Cameras Logo
127 people viewed this question
Top Video Cameras Experts
Marvin
Marvin
Are you a Video Camera Expert? Answer questions, earn points and help others
