Exercise & Fitness Logo
Marisa Ramirez Posted on Nov 26, 2018
LifeSpan TR 200 Treadmill - E7 error (incline motor). We turned the treadmill over and saw that the incline screw came unattached from the motor. We reattached but the treadmill still gives us the E7 error and won't allow us to reset the incline down to a neutral level.
4 Related Answers
Anonymous
  • 6 Answers
  • Posted on Mar 25, 2010
SOURCE: Treadmill incline error
Try this, it fixed it for me, if it doesn't work let me know
http://www.youtube.com/watch?v=MIIxoPtvhy8
I bought a used Precor 9.4 treadmill, but the incline adjustment was not working.
So, I did the following.
1. Turn off, unplug the treadmill and wait for an hour (this is for safety
2. Remove the black motor cover
3. Observe the transformer to the right of the motor and towards the belt ( I point to it in the video)
This transformer converts DC electricity to AC electricity and the AC current goes directly to the Incline motor which is in the black box towards the front of the machine.
4. On mine the wires had come loose from the transformer, they were soldered on very poorly, the wires are stiff and you should be able to see 4 wires coming from the top of the circuit board and plugging into the transformer, I had three of the 4 wires loose.
5. If you are not comfortable working with electronics or soldering DO NOT DO THIS REPAIR, you could get shocked very badly if you just go poking around in there with metal objects, get a friend who knows how to solder or hire someone.
6. It took about 5 minutes I just heated up my $10 soldering gun from radio shack and soldered all the loose wires that were about a millimeter away from the tabs on the back of the transformer, and VOILA! The incline now works!
Anonymous
  • 83 Answers
  • Posted on Apr 29, 2010
SOURCE: Lifefitness TR 9000 treadmill - 1997 model
Because you are hearing the lift motor making a noise, it sounds like the gears in the motor are bad. The fix is to replace the lift motor.
Lex Smith
  • 44 Answers
  • Posted on Dec 13, 2011
SOURCE: treadmill won't run the screen is showing E7
You probably need a technician to look at it. I would say the motor that runs the treadmill is faulty due to a fuse that has blown you would have to locate where this is first replace it and proceed to the nxt step. I say you may need a technician cos often you are dealing with mains power or small dc voltage in any case one should carry this out in a safe way.If you are not confident ring a professional Tech.
ercupa190
ernesto cuadra
  • 12223 Answers
  • Posted on Mar 10, 2012
SOURCE: How to bypass the incline motor set up on the Trojan stamina treadmill
Dear Sir:
Adjust the sensor speed and clean see diagram
After that RUN the software calibration for easy diagnose and troubleshooting.
See my personal TIPS for diagnose and Help.
Do not Bypass any motor this machine is very advance electronic computer system. IF you do it, only will complicate the system and damaged.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a.
TENGO LA MAQUINA CORREDORA DK CITYFITNESS SI PRENDE PERO EN LA PANTALLA ME SALE E7 QUE PUEDO HACER?
The E7 code means the potentiometer value the console is reading from the lift motor is out of range. This can happen when there is a bad wire harness connection or a damaged wire harness.Jun 30, 2021
Treadmill Error Codes and Troubleshooting - LifeSpan Fitness
And videos
https://www.google.com/search?q=DK+CITY+FITNESS+TREADMILL+E7+error
ENGLISH only on Fixya.
How do I fix an error code dC-6 on a LifeSpan TR3000 treadmill?
  1. Power OFF and ON.
  2. If the error is still shown, turn the treadmill OFF and unplug from the wall outlet. Find the cable that goes between the board under the motor cover and the console. Unplug any connections and replug.
  3. If the error code is still shown please contact customer service.
1helpful
2answers
Hi i have a e7 code on my lifespan fit e3i elliptical help please
For E6 and E7 codes, while this code is displayed:
First, press and hold Level Minus, then the Start key (the Level Minus key first), for 2 seconds. (make sure you press Level Down a little before Start.) The console should beep twice; the display does not change.
If the potentiometer value on the left of the screen is higher than 240, press and hold the Ramp minus key to lower the ramp until the value is in a range between 48 and 240. Then release the button. May reset by itself now. Or, turn the elliptical off and back on to reset. If ramp goes up to 255 and won't move in any mode, unplug power for 20 minutes.
If the potentiometer value is lower than 48, press and hold the Ramp plus button to raise the incline until the value is in a range between 48 and 240. Then release the button. May reset by itself now. Or, turn the elliptical off and back on to reset.
Now press Start, and pedal for 30 seconds. The ramp should reset to zero, the lowest level.
Error code message
What Does Your Treadmill's Error Code Mean? - LifeSpan
www.lifespanfitness.com/.../what-does-your-treadmills-error-code-mean
Free
May 21, 2015 - If the running belt stops after 6 seconds of starting the treadmill, this may indicate that either the ... If there is no belt movement, or you notice a burning smell coming from the motor area, this ... An E6 or E7 error code is an incline error code. ... This will cause the incline motor to raise the running deck up.
[PDF]ERROR CODES: ADDITIONAL ERROR CODES:
www.gympart.com/TSB/.../Treadmills/.../Sportsart%20Error%20Codes.p...
ERROR 6: INCLINE ERROR - CHECK INCLINE OPERATION AND CALIBRATION. ERROR ... ERROR 1-1: AC SERVO ERROR - AC SERVO MOTOR ENCODER HAS FAILED ... error codes listed by category: treadmills, bikes, elliptical trainers. ...ERR1 Condition 1: Press speed key; walk belt doesn't move; ERR1 appears.
[PDF]Error Code Troubleshooting Guide
BH fitness pioneer start treadmill- flashing E7
see this error has 2 alternatives. proceed according. God bless you
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
What does Error E7 indicate? Thanks!!
Elv. Motor out of range Calibrate elevation motor
On/Off Switch Check if unit is turned on
Fuse Check fuses on MCB
Insufficient power source Plug unit in a dedicated
120V, 20A outlet
Run software calibration for easy diagnostic and fix it.3af94116-465b-4b36-b53e-109e9b5ccac3.gif
God bless you
What does E7 mean on Lifespan TR4000i?
see the 2 alternatives that the error code 7 means:
2)Alternative:
However RUN the software calibration for diagnostic, troubleshooting and Fix it.
God bless you
Repco fitness Treadmill error E7
This happened to mine, e7 is an error in the incline, meaning that the incline is too high or too low in the accepted range for the starting position of the treadmill. When the treadmill starts it looks to see if the incline screw shaft of the incline motor is in the correct position. If it isn't it gives the error message and shuts down. This happened to us after we had moved and the treadmill was bumped around a bit, this caused the incline worm shaft to move out of position, and that is why we got the error message.
To fix the problem I just took the cover off the motor area of the treadmill (WITH THE POWER OFF AND CORD DISCONNECTED) and located the incline motor, it has a threaded rod and a big nut coming along side the motor itself. It is the smaller motor. On the end of the threaded shaft is a plus sign cut into the shaft, so that you can insert a philips head screw driver into it and rotate the shaft. The shaft will rotate easily in one direction. Insert the screw driver into the end of the shaft and rotate the shaft so it goes as far into the big nut holding it as you can, don't twist it tightly, just make sure that the shaft has gone all the way in without binding, it still needs to rotate freely in and out. Put the cover back on and then switch it on. The treadmill should now start right up.
1helpful
Top Lifespan Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
john h
ADMIN Andrew
ADMIN Andrew
Are you a Lifespan Exercise and Fitnes Expert? Answer questions, earn points and help others
