Washing Machines Logo
Redha Djeridi Posted on Nov 26, 2018
I have a washing machine daewoo model DWD_T125RDP and i need to change the full door ,where can i find it please?
5 Related Answers
Anonymous
  • 770 Answers
  • Posted on Aug 02, 2008
SOURCE: Daewoo Washing machine Problem
If it is new then it is under warrty plz call the dealer you bought iy from for service
Anonymous
  • Posted on Dec 27, 2009
SOURCE: Daewoo washer - LE error message
replace the lock switch
Anonymous
  • Posted on Feb 11, 2011
SOURCE: Daewoo wash machine air power 7kg Model DWD-F1013.
i bought used but good working daewoo f1013 washing machine in dubai,
i can not spin. no drying. i dont have user instruction manual.
please help
Anonymous
  • Posted on Aug 30, 2011
SOURCE: Daewoo DWD G1243S washing machine
When you hear that macinhe is beeping and giving 1E code, turn it off and make sure that water feeder is turned on and that it can feed water into the machine, turn it back on and start your program, it should be fine :) .... Good Luck....
Anonymous
  • Posted on Dec 19, 2011
SOURCE: daewoo DWD-F1011 PFE error code
I hd zs problem before,no problems in z water outlet,z pump
Daewoo washer DWD-F1011, WATER OVERFLOWING, HOW TO SOLVE THIS PROBLEM???
replace the water shutoff solenoid valve assembly
in the mean time when the machine is full turn the tap off
change the hot water hose over to the cold water tap and use the hot water solenoid button
Daewoo DWD-F1011 1E error code I have a daewoo washing machine model DWD-F1011 and it start working the wash before no working spin and gives error code 1E. Any idea what that might be?
I do not believe that is a 1E I think it's an IE error code which would be water inlet wiring or something like that. Here is the code list, scroll down until you find IE, Daewoo errors start at E2, hope this helps.
http://removeandreplace.com/2015/11/02/daewoo-washing-machine-error-fault-codes/
I have a daewoo washing machine dwd-g20dl showing error code LE
LE Washing machine door opening error
The washing machine or washer dryer door has been detected as open or unlocked.
·Close the door!
·Check the door lock switch
·Check the door latch
·Check PCB
I believe the EO code means the pump is blocked, and you will have to clear the pump for it to work again.
2answers
How to change the switch door lock
What is the model number of your unit?
7helpful
3helpful
3answers
5helpful
2answers
Daewoo DWD-F1011 PFE error code
Top Daewoo Washing Machines Experts
Paul Bade
vince
Are you a Daewoo Washing Machine Expert? Answer questions, earn points and help others
