Question about LG Dishwashers
How to fix error LG DISH WASHING machine doesn't release water
    Top Expert:
  • LG Master
  • 63,596 Answers
WITHOUT ANY TESTING IT MIGHT BE 1 OF SEVERAL PROBLEMS . PUMPS FAIL, FILTERS CLOG ,POWER CONTROL BOARDS FAIL .
Posted on Dec 20, 2018
SOURCE:
SOURCE: my LG Tromm washing machine
what do the letters UE mean on my Tromm front load washing machine?? PLEASE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! I P
Posted on Oct 10, 2008
ltfrc
  • 227 Answers
SOURCE: hoover optima AAA1600 hntf 6167 washing machine
Most washers have a drain hose that is mouted high to keep the water in. If you drop the hose to floor level it will drain with out help. Be sure you have a floor drain or bucket. Then check the belt on the motor if there is slack it will not engage the pump for drain to operate. Need to tighten the belt.
Posted on Jan 19, 2009
SOURCE: LG washing machine displaying error
It's actually a DE error code which stands for drain error. Pull the little basket out that's behind the small door on the lower left front (where the drain hose is) and look inside. The drain pump intake is about an inch in on the left. Make sure there's nothing in there like a paperclip or hair pin. If possible reach in and see if you can turn the impeller. If it won't move there's something in there if it will turn then the motor is probably bad.
worked for me
got this from mark1963
Posted on Jun 06, 2009
blueextc3221
  • 15935 Answers
SOURCE: Hi I have a problem with a lg washing machine it will not fill up
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG has some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 18, 2010
SOURCE: PE - LG Washing Machine WFT7012EN
I am finding a PE error as I try to use my washing machine this morning. Is there any quick fix for this?
Posted on Aug 29, 2011
We keep getting an error message E1. We have an LG 2120 model
The E1 or 1E error or fault code indicates that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve.
Dec 13, 2014 | LG Dishwashers
LG 2131SH Dish Washer giving error code E1
That is a leakage error, pull the access panel and check for water underneath the unit that might be cuasing it to fault out
Jan 31, 2014 | Washing Machines
Dishes come out feeling gritty. Using Finish doesn't help
If you open the door immediately after the dishes are washed, and before the "dry" cycle, is the water hot enough to have "steam" coming out of the machine?
You should be able to feel the heat.
If not, perhaps the water is not getting hot enough to dissolve the dishwashing powder.
Could you try using a liquid soap once and see what happens?
Be blessed.
Feb 17, 2013 | LG Dishwashers
My lg intellowasher wf t8501tp won't go into a
Check the pressure switch and hose. Pressure switch is what turns the pump on and off. Trouble is usually in the hose so check it first. Look for the hose to be unattached or clogged.
Jan 13, 2013 | Washing Machines
No water drains out of drain plug on Lg washing machine
hi there, this could be one of two problems 1, you have a block in the waste pipe or pump? or 2, your drain pump has packed in and may need replacing?
however if memory serves me right there is an emergency drain tube on LG machines, it should be located behind the bottom pannel on the front of the machine and from there you should be able to release the water from the machine. hope this helps!
Jul 04, 2012 | LG WM Washing Machines
Machine doesn't drain & spin, it says "OE" or sometimes some other message "E something"
Here is a tip that I wrote that gives more detail about how to fix the OE codeon LG washers....
LG Washing Machine OE Error Code
heatman101
May 23, 2011 | Washing Machines
LG front load washing machine WM2233H Error code is FE
I found this information on the internet. I hope that it helps.
" Getting fe code on lg washer.
"This means that the washer is overflowing. This is a built in fault that turns on the drain pump so that the water doesn't get so high that it gets into the floor. If water is continually flowing into the washer you will get this problem. If this is the case the water valve is most likely the problem. To confirm unplug the washer and if the water doesn't stop flowing into the washer the water valve is the problem.
Thank you,
Shawn"
I hope that this helps you out
Apr 21, 2011 | LG WM2233H Front Load Stacked Washer /...
Feb 27, 2010 | LG WM1814CW Front Load Washer
Water spilling
If water is spilling from the soap tray, try closing the water supply taps a little. Your water pressure may be too strong for the machine...common issue for front load machines when being used on water lines that have not been properly regulated.
Aug 05, 2009 | LG WM-2277HW Front Load Washer
LG front loader not filling properly
You have to remove the top of machine to have access here. Plug off the wall; you need a grip plier to loosen the clip to see what is blocking the hose.................refit carefully & firmly.
Nov 03, 2007 | Kenmore 44102 Front Load Washer
Dishwashers Logo
64 people viewed this question
Top LG Dishwashers Experts
Marvin
Marvin
Mike
Lollo Pop
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
