SOURCE: my keys are inside the car- toyota 2003 Ce- manual lock.
call your triple A Co. or tow truck provider. Special tools are used and are not available to the general public. If its an emergency break the side window and deal with replacing the glass later.
SOURCE: The Yale lock on my
Yes I would useWD-40 to spray in lock. Insert key part way in lock and spray a small amount on key and into lockset if tou can, If you can fit spray nozzle into keyhole ,and spray liberally. You can also use dry graphite to lube lock mechanism. I would check to make sure that your keys aren't bent or worn to the point that I hope this helps you. Thanks they can't engage all tumblers inside lockset. I would also make sure that latch on lock is lining up with strike plate in door frame. One easy way to do this is to use a felt tip marker to cover strike plate on door frame and open and close door several times. Where ink from marker is rubbed off will show you where latch is contacting strike plate. If it is out of aligmment this will make it harder to open or lock with key. If necessary adjust strike plate for better fit. I hope this helps you. Thanks
SOURCE: i have a digital home
i have digital home safe 701-5359 and left keys inside and batterys have gone
SOURCE: the combination on my Yale Y 150 changed when i locked it how do i open it now?
sorry my friend you are just going to have to break it to get it off once that happens you can change it
SOURCE: The safe is locked and the Keys inside how we can open it manually since we forgot the code Thanks
I'm almost 100% certain that the safe you have in your possesion has an eight (8) digit combination number/letter security code. I believe that the code is: RLYSUX4U
Always Be Safe,
Mr. Ullsaw A. Lotmore
Yale battery operated safes have a manual override function for which keys are supplied.
