Question about Jabra Radio Communications
How do I make a call with a Jabra Talk 55? It is paired to phone, and I can receive calls but don't know how to make a call. User's manual online has no reference to making a call, only answering
  • Jabra Master
  • 26,370 Answers
Press the button the headset once and say 'Hey Siri, call Andrew Taylor".
It is dependent on the phone it is attached to and the operating system the phone uses, not the headset. That is why it isn't mentioned in the manual. Any Smartphone should work on a spoken command. If you have a Nokia 3310, not so good. :>)
Posted on Nov 25, 2018
  • jfkga Nov 25, 2018
    Have Samsung S6,tried Google Now, Cortana and "call", get nothing. Looked in settings for help - nothing.
  • Andrew Taylor
    Andrew Taylor Nov 25, 2018
    Here you go
    Voice dial a contact
    From the Home screen, tap Apps.
    Tap the Samsung folder.
    Tap S Voice.
    Tap the microphone to activate it (if necessary).
    Speak Call + [name of contact].
    https://support.t-mobile.com/docs/DOC-29...
    This video shows how to set S Voice to Set it up to specific commands. You may need to set up Commands specific to the people you call most. The iPhone just accesses you Contacts list and dials who you ask.
    https://www.youtube.com/watch?v=Mi1RRTS7...
SOURCE:
SOURCE: Cannot Get Jabra BT150 into Pairing Mode
I had problem with my bluetooth not getting into pairing mode,and Now it working good.
Thank you for your best solution.
Posted on Nov 17, 2008
SOURCE: how can I pair my Jabra BT2035 with my ps3
After registering the bluetooth device ( in the settings> accessory settings> register bluetooth device) you must then go to the audio options in the settings >accessory settings >audio options and switch the input from do not use to use to the name of your bluetooth to turn on the connection from the bluetooth to your ps3
Posted on May 18, 2010
supernova278
  • 1932 Answers
SOURCE: Just purchased Jabra Cruiser 2.
Try to reset and pair it.To reset follow below instruction
To remove the list, press and hold the Answer/End button, Volume up button and FM button at the same time. A beep indicates the list was removed from the speakerphone memory. The next time you power on, the speakerphone will go into pairing mode as the first time you powered your new Jabra CRUISER on.
Thank You
Posted on Nov 15, 2010
SOURCE: have jabra bt2050 and paired with my ps3 but cant
settings > accesory settings > audio device settings > there you should be able to select the input/output device.
Posted on Jan 01, 2011
SOURCE: need to put jabra hsf001 into pairing mode
I NEED HELP WITH THIUE JABRA HFS001
Posted on Jan 03, 2011
Jabra talk ps3 problems
i got the same problem. hope sum1 knows whats wrong cuz i dont.
Aug 09, 2012 | Jabra Cell Phones
I can not get the headset to turn on.
If I read everything correctly in the manual I believe the light only stays on when the device is in the pairing mode. If the light flashes every second, the headset is on a call, if the light flashed every three seconds, it is in standby mode.
Standby mode: is when the Jabra BT160 is passively waiting for a call. When you 'end' a call on your mobile phone, the headset goes into standby mode.
Make sure your phone is bluetooth equipped.
You must first successfully pair the headset with your phone. The manual shows you how.....
1. Put the headset in pairing mode Make sure that the headset is on. Press the answer/end button and press the volume up (+) button at the same time, until a solid blue light comes on.
2. Set your Bluetooth phone to 'discover' the Jabra BT160 Follow your phone's instruction guide. This usually involves going to a 'setup,' 'connect' or 'Bluetooth' menu on your phone and selecting the option to 'discover' or 'add' a Bluetooth device.
3. Your phone will find the Jabra BT160 Your phone then asks if you want to pair with it. Accept by pressing 'Yes' or 'OK' on the phone and confirm with the passkey or PIN3 = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing, repeat steps 1 to 3.
Go here for a copy of the owners manual....
http://www.mainresource.com/PDFs/GNBT160User.pdf
Hope this helps.....
Jan 27, 2018 | Jabra BT160 Wireless Headset
How do I get the jabra to work. I don't have my manual handy
If, at the moment you turn your carkit on, the sentence 'Pairing mode' isn't announced, press and hold the answer/end button for some 5 seconds, until you hear that announcent. Then, make your phone's bluetooth application search for new devices. After a little while, your car kit should appear on the phone' screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros).
By the way, you can download your car kit's user manual from this location. There you will find more detailed informations on how to pair it with your new phone. Hope you find it useful. Anyway, please, let me know if you need further assistance.
Regards, Carlos
Jul 09, 2011 | Jabra Cruiser InCar Speakerphone Black
I have a samsung phone and i am trying to pair it with my jabra vbt185z but i don't know the passkey...i tried using 0000 but that didn't work. so what else can i do to make it work?
You do need the passcode. It should "auto pair" but the default passkey or pin is 0000 (4 zeros.)
Here is a link to the user manual
http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT2010/Documents/UM/VBT185z_UM_6198.pdf
Headset Pairing Readiness Instructions:
1. Fully charge headset for two hours.
2. The headset will automatically go into pairing mode if no device has
been previously paired.
3. Set your mobile phone to 'discover Jabra VBT185Z'.
4. Enter passkey or PIN = 0000 (4 zeros), then press Yes or OK.
dw
Dec 31, 2010 | Jabra BT150 Wireless Headset
I do not have manual for jabra bt160 how do i connect to phone
Wear it how you like it 4
5
English
The Jabra BT160 is ready to wear on your right ear. If you prefer the left, gently flip and
rotate the earhook 180°. (See fig. 2 )
For optimal performance,wear the Jabra BT160 and your mobile phone on the same side
of your body or within line of sight.In general,you will get better performance when
there are no obstructions between your headset and your mobile phone.(See fig.5 )
Answer a call
Tap the answer/eend button on your headset to answer a call
End a call
Tap the answer/eend button to end an active call
Reject a call (DDependent on your phone supporting this feature)
Press the answer/eend button when the phone rings to reject an incoming call.
Depending on your phone settings, the person who called you will either be
forwarded to your voice mail or hear a busy signal
Make a call
• When you make a call from your mobile phone, the call will (ssubject to phone
settings) automatically transfer to your headset
Activate voice dialing (DDependent on your phone supporting this feature)
Tap the answer/eend button. For best results, record the voice-dialing tag through
your headset. Please consult your phone ’ s user manual for more information about
using this feature
Redial last number (DDependent on your phone supporting this feature)
Adjust sound and volume
Press the volume up or down (+or – ) to adjust the volume (See fig. 1 )
How to...5
Before you use your Jabra BT160, you need to pair it with your mobile phone.
1. Put the headset in pairing 2 mode
Press the answer/eend button and press the volume up (+) button at the same time,
2. Set your Bluetooth phone to ‘ discover ’ the Jabra BT160
Follow your phone ’ s instruction guide. This usually involves going to a ‘ setup,’
‘ connect ’ or ‘B luetooth ’ menu on your phone and selecting the option to ‘ discover ’
or ‘ add ’ a Bluetooth device.** (See example from a typical mobile phone in fig. 4 )
Pair it with your phone 3
English
Turn on your headset 2
Press the answer/eend button to turn on your headset
Press and hold the answer/eend button to turn off your headset
Charge your headset
Make sure that your Jabra BT160 headset is fully charged before you start using it. Use
the AC adaptor to charge from a power socket. Connect your headset as shown in fig. 3.
When the LED is solid blue, your headset is charging. When the solid blue LED turns off,
it is fully charged.
The Jabra BT160 is easy to operate. The answer/eend button on the headset performs
different functions depending on how long you press it.
Instruction:Duration of press:
Tap Press briefly
Press Approx: 1 second
Press and hold Approx: 5 seconds
Getting started
Your phone then asks if you want to pair with it. Accept by pressing ‘ Yes ’ or ‘ OK ’ on
the phone and confirm with the passkey or PIN 3 = 0000 (44 zeros).
http://www.jabra.com/Sites/Jabra/UK-uk/support/Pages/JabraBT160.aspx
It is all in there www.jabra.com
ARTGIRL
Jul 18, 2008 | Lands Phones
Jabra and Krazor problem
on jabra try holding vol butten and talk swich hold it till it blue light stars continue and then try surching in ur phone reply me
May 18, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Pairing Jabra 250V with Nokia 6300
u sould push the jabra buton until is blinkin red and green and go to
settings>bluetooth>search audio enhanc u sould see the jabra then u will be asked for a password type the password that u received with your jabra
Apr 20, 2008 | Nokia 6300 Cellular Phone
Pairing
http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT150/Documents/User%20manual/BT150_UM_NA_EN_496.pdf
Manual for Jabra BT 150
Go to page 4 Pair it with your phone
Did you know that if you have a bluetooth card in your computer you can also use this headset to listen to music. Do it everyday. It's great!
Mar 22, 2008 | Jabra BT150 Wireless Headset
Can't work out how to pair it with Blackberry Pearl
You can download the manual from the link below: http://www.jabra.com/Sites/Jabra/na-us/pages/SupportProduct.aspx?productid=f3078775-ed17-4b07-b828-9b1157e930ce There is a good online pairing guide that will take you through the necessary steps: http://jabra.pairx.co.uk/ Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 22, 2007 | Jabra BT250 Consumer Headset
Radio Communications Logo
159 people viewed this question
Top Jabra Radio Communications Experts
Bobby G
Bobby G
Damen Wong
Damen Wong
Jerry Greenberg
Jerry Greenberg
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
