My HP Officejet 6000 just decided to stop printing black ink a few weeks ago. I have reset the printer, changed the black ink cartridge, cleaned the contacts and ran the printhead cleaner more that 3 cycles, I also replaced the printhead. Do you have any other suggestions before I throw it in garbage? Anna
Check whether there is a wet ink inthe ink pad at the bottom of the head. If not the gear in the link flush section may not working properly.
Try taking out the printhead and let it soak in "window cleaning" solution overnight or for about 8 hours. It should unclog the printhead nozzle. Put it in about half inch of the solution. It always worked for me. Make sure you wipe it dry un the back of the printhead when putting back into the printer.
SOURCE: officejet d135 - "Supply Expired" error message
HP, in order to sell more ink, monitors the expiration date of the cartridges installed. Solution is either to buy a new unexpired cartridge from HP or to disable the date monitoring built in to the printer. This latter is done by removing the button cell located inside the D135 printer on the left hand side or by simply slipping a thin piece of plastic between button cell and metal contact. You will no longer have date function on printer, but it won't object to expired cartridges either.
SOURCE: Blank Ink not pumping to print head
Turn off the device after removing the printhead
After removing the printhead, turn off the device, wait about 20 seconds, and turn it on again without the printhead installed. After it has restarted, reinsert the printhead.
it will go through this long routine of perhaps 20 min or so. after its compleate it should print great.
SOURCE: HP J5680 is printing and scanning vertical gray stripes
The fix is on this link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00704831&cc=za&lc=en&dlc=en&product=3301296
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: HP officejet Pro L7580 print head is not working properly.
i order the 8 jan 2010 2 print heads No : 88 (ref hp c9381a for black/yellow and ref hp c9382a for magenta/cyan) and i receive it after 4 days.
