Check it over and look for the motor and make sure the fuse has not popped out. it will do that for many reasons but mostly if not enough power is available when running or ran too long and got hot.
the fuse should be on the back cover, its more like a button that you would have to simply push in again. would be about the size of a screw head. if not you may have to take cover off. what is the complete symptoms of not starting. does it hum or anything. A hum will indicate that it is not a fuse and something else.
SOURCE: coleman powermate inflationmate pump
The ring is gone on compressor. You can buy replacement pistons and rings from colemen. Comes with instructions.Good luck
SOURCE: Coleman Powermate Inflationmate portable 4 gallon
Use a 15 amp 'time delay fuse'. Any time you start a motor, the inrush current will blow a regular fuse. Motors pull high current to start then drop to normal after 1 or two seconds. The time delay will fix it up!
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Dnt know where the fuse is
the fuse should be on the back of the compressor its fairly small and could be as easy as push back in. but does it hum when turned on or plugged in? did you try plugging it in and rocking the switch to on and off a few times to make sure it wasn't a sticky switch. and does it hum if it hums then its not a fuse may just be stuck and can be unstuck too. let me know what you find please.
