Question about Pride Health & Beauty
Why would I need to press the reset button on circuit breaker
Pro Rider Road King not charging properly , not done anything different over past year
SOURCE:
wd4ity
  • 4565 Answers
SOURCE: Just need to verify the
Harley puts these things in so many places on some many different years and models of bikes that it's very difficult to keep up with. Usually on Road Kings. the main circuit breaker is under the seat or the right side cover. But, I can't swear to it.
Good Luck
Steve
Posted on Mar 14, 2011
MicrowaveSvc
  • 9156 Answers
SOURCE: GE MICROWAVE jvm13508w 002 trips
Years? Wow! I'm glad it hasn't caused a serious problem or fire!
In some cases, this is due to a bad door switch or door switch mount, or a shorting high voltage capacitor.
If you or someone you know can do testing, first see these files:
http://031d26d.namesecurehost.com/mwd/safety.txt
http://031d26d.namesecurehost.com/mwd/disassembly.txt
http://031d26d.namesecurehost.com/mwd/doorsw.txt
Then see this:
http://www.gallawa.com/microtech/cap_test.html
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
That model should be "JVM1350BW002", by the way.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Posted on May 26, 2011
SOURCE: pro rider scooter road king
The Problem was resolved by Pro Rider under warranty including 2 new front wheels. The scooter is now running better than ever!
Posted on Aug 27, 2011
gewiz
  • 1367 Answers
SOURCE: Need Manual for a Pro Rider Road King Mobility Scooter or a model number to help with search
as you're aware they are based upon a shoprider , can i ask what you need information on as i have repaired quite a few over the summer ?
regards
Posted on Dec 09, 2012
alstreck
  • 19 Answers
SOURCE: Hi I have just bought a second hand pro rider road
Look for a Silver, three prong plug under the seat. Sometimes it is on the left side of the battery.
Posted on May 22, 2014
2006 road king dead battery,when I try to jump start jumpers get hot,bad battery or starter problem.
Hi, Dave before testing any electrical component in the Starter Circuit it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test because your battery may have 12.5 volts or more but little or zero amps causing the battery to be faulty and must be replaced, especially "AGM" batteries.
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter.
4. Bank angle sensor needs a reset or is faulty.
5. FOB battery low or dead.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand or clutch pull in switch/sensor.
9. Security alarm needs a reset.
10. Starter relay, solenoid, starter have failed or circuit wiring faulty.
11. Starter armature or field coils have failed.
12. Main fuse or circuit breaker may be blown or faulty.
13. The electric starter is working but starter clutch has failed.
14. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
2005 Harley Davidson FLSTNI Deluxe Battery Load Test
Testing the Battery and Charging System Harley Davidson FXSTC
https://www.carlsalter.com/pdfs/Harley_Davidson_FLHRC%202006%20Maintenance%20&%20Repair%20Manual-Full.pdf
http://partsfinder.onlinemicrofiche.com/ronnies/showmodel.asp?make=hdmc
http://mybikemanuals.com/harley-davidson/2006-harley-davidson-owners-manuals
Instant Tech Relief To speak to me personally absolutely "FREE"
Apr 29, 2017 | 2006 Harley Davidson FLHR Road king
How can you find the year a used pro rider road king mobility scooter was manufactured
You should be able to find that out from the serial number and a call to the manufacturer.
Jun 23, 2016 | Pride Health & Beauty
regards
Nov 28, 2012 | Health & Beauty
Pro rider scooter road king new front tyres after 15 weeks ever since new tyres fitted violent shake on the front end
Aug 23, 2011 | Health & Beauty
Heard a loud pop then 2003 harley road king died and is totally dead is there a master fuse or curcuit breaker of some kind and if so where is it located?
Circuit breakers are under the seat. There are several. Charging system failure and subsequent battery failure can cause complete failure, also. Inadvertantly hitting the kill switch?
Apr 17, 2011 | 2003 Harley Davidson FLHR Road king
Just need to verify the location of the main circuit breaker on my 1997 Harley Road King
Good Luck
Steve
Mar 12, 2011 | Harley Davidson FLHR-FLHRI Road king...
Location for the fusebox or fuses for the turn signals front and horn. On a harley davidson road king 1998
I'm not sure when Harley changed to fuses but I think your RK has circuit breakers. These sense an overload and trip the breaker. After a short time, the breaker resets. They are usually under the seat. they look like small metal boxes that measure about 1/2" X 1/2" X 1 1/4". They have a copper screw and a steel screw. The copper screw is the battery end of the breaker.
Good Luck
Steve
Sep 02, 2010 | 2006 Harley Davidson FLHR Road king
Health & Beauty Logo
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
