Question about Casio Watches
How do I remove my new casio watch from the hard plastic display case?
    Top Expert:
  • Casio Master
  • 51,372 Answers
You may have to cut the case open, using care to prevent damaging the watch.
Posted on Nov 24, 2018
4 Suggested Answers
SOURCE:
chad7houston
  • 62 Answers
SOURCE: I have a Casio baby-g
http://www.casiosalesandservice.com
Not sure if they carry this particular bezel or not, but if they don't your only other option might be to look for a used one on E-bay.
Hope this helps,
Chad
Posted on Oct 09, 2008
SOURCE: Casio Wave CeptorModeule #2735
I drilled a coupleof very small holes in the plastic part of the case and also in the watch band where it attaches to the case. I mixed strong epoxy glue (two part) and held the two pieces together with clamps over night. That was 6 months ago and it is still holding. The holes helped squeeze the glue into the joint. Good Luck!
Joe
Posted on Nov 11, 2008
SOURCE: Casio G plastc watch case holder replacement source.
i need a replacement case for g shock gw-002e,any ides where i can get 1.im in essex,uk
Posted on Oct 21, 2009
Hello, I have a new Casio 5208 watch and the analog is stuck on 12 o'clock, no digital display,
pull the small plastic tab from behind the crown so that the battery is allowed to work
Dec 29, 2017 | Casio Watches
How can i get water out between 2 glasses on casio pro trek 2894
Hi Dirk
Bad one having water inside your Protrek or any watch for that matter-mechanical or electronic.
It means one of your seals has failed most likely the back one.
Look carefully at the back seal, if you squeeze the back plate, and the main case between your thumb and index finger you may notice a slight movement (use x10 magnification) That microscopic gap is enough to flood your watch and the deeper you use it the bigger the flood. The problem is the case, it is made of cheap nasty plastic and over time it deforms and the rubber seal contracts. Any slight over tightening of the screws, pulls the plastic thread out and stops the back plate making a good seal between the back plate and the rubber seal in the groove of the main case. For the price one would be excused for expecting that these Casio watches had a better quality case, even better a screw on back plate (like a proper 100m depth watch) rather than the individual 4 screws at each corner and a prayer. There are ways of fixing the screw threads but it never lasts....
To get the moisture out, just remove the backplate and discard the batteries. The sooner this is done the better the chances of success. Leave the watch open, face down in a warm place, preferably loosely covered by a glass bowl to stop dirt getting inside. After few hours check if the water is gone. If on inspection of all the contacts they do not exhibit any rust or white chalky deposits. Replace the new batteries and reset the watch by shortening the reset pins. If all seems ok and you have a proper display and all funtions works. You may purchase a new seal from Casio or simply clean the existing one with a little blu-tak to remove the dirt and run A LITTLE!! bead of vaseline along the rubber top to aid the seal.
I will not use the watch under water anymore and chances are that it will be downhill for the watch from now on, sorry.
I hope this helps
Jan 25, 2017 | Casio Watches
Digital display on my NEW casio baby g is too faint for me to see
I fix watches as a hobby, and I had a few that corrected this by replacing the battery. If that does not work then the quartz movement probably got wet. you would have to pop the case open remove the movement and clean it gently with a q-tip. You will also be able to see if the issue is with the plastic case that can probably be faded from wear or moisture. The plastic case can be cleaned with a q-tip with alcohol. Be careful not to get any liquids, magnets or dirt near the movement. I hope this helps! Marcelo
Feb 20, 2013 | Watches
I recently changed the battery on my casio 437 watch and now it won't turn on
There is a 437 stamped into the back of the case for one of the two versions (437 and 438) of Casio WR watches, with the 437 being the kind with raised rubbery number buttons. The model no. for the 437, also on the back case is CA-53W, useful for ordering parts (see below). These instructions are for the 437 but should be useful in many cases for other Casio watches, with numbers other than 437 or 438 on the back of the case. For example, the resetting process described in step 5 below appears to be common to many if not all Casio watches. There is no manual on the casio.com website for many watches, including the 437 and 438. There are no instructions for changing the watch battery in the manual for the 437 or 438 either, nor for many if not all Casio watches. If there is a 438 stamped on the back of the case, the chip is the same as on the 437. The buttons on the face of the 438 watch are flat plastic rather than raised and rubbery. The two buttons near the top serve the same function on the 438 watch as the right side buttons on the 437. The left top button on the 438 corresponds to the top right side of case nonindented button on the 437. The right top button on the 438 corresponds to the bottom right side of case lower indented button on the 437. Save time and money by replacing the battery yourself If you send your Casio watch off to have the battery replaced, it will likely cost you about $30 USD. Many jewelers will routinely send a Casio watch off for battery replacement rather than replace the battery themselves, so these instructions may help save you from delays and expense if you do it yourself. Likewise, jewelers may find these instructions useful for satisfying customers by replacing the battery on the spot rather than having to send the watch off to Casio. Materials needed a. 5/64" Phillips head screwdriver (A set of different size screwdrivers in a small black plastic case, including the 5/64" was bought for $1 USD at a local Dollar Tree store in the USA.) b. Watch battery identically numbered to the dead battery on the watch (2016 on 437 case back number) c. Metal tweezers to reset the watch d. Sil glyde gel grease or any other grease, to maintain water resistance f. Toothpick or similar to spread grease in O ring slot g. Ziplock plastic bag or bowl to hold the 4 small screws so they don't get lost Instructions on replacing the battery and resetting the watch 1. Take off 4 back screws, using the 5/64" Phillips head screwdriver. One screw was balky and needed to have the screwdriver handle attached to a vise grip pliars, with the watch held in the other hand and rotated. Putting the screwdriver handle in a vise would also work to stabilize the screwdriver, while turning the watch held in one hand. Set the 4 small screws aside in a ziplock bag or bowl. 2. Remove the red cellophane cover on the battery, held by two tabs cut into the cellophane fitting into a slot on the metal hold down battery strap atop the battery. 3. With a fingernail or toothpick (nothing metal), slide the battery to the side, out from under the metal hold down strap atop the battery. 4. Insert new battery with fingers/fingernails, sliding it into place from the side. The side, with the battery number showing (2016 on 437 case back number) faces outward, just as on the removed battery before it came out. The watch will continue to appear dead, with nothing showing on the display until the electronics are reset in step 5. 5. Reset the electronics by using a pair of metal tweezers to simultaneously touch with metal, the outward facing side of the battery, and the brass terminal in an indentation in the plastic about 4 o'clock and about 1/8" outside the battery diameter. To aid in orientation, there is a barely visible small AC (presumably meaning "all clear") pressed into the metal near the battery and the indented brass terminal at about 4 o'clock. It may be necessary to tilt the watch in the light so the light strikes the AC so it becomes visible. Verify the display is working. Resetting the time will be in step 11. 6. Reinsert the red cellophane cover removed in step 2. It may be necessary to slide a knife or similar between the strap holding the battery down, and the battery, to make room for the two cellophane tabs to be inserted in a small air space between the strap and the battery. (When installed, the cellophane tabs do not prevent current from flowing between the top of the battery and the battery hold down strap.) If you use a knife or other metallic object to open up the strap to battery space to allow entrance of the cellophane tabs, take care not to short the battery against metal parts of the watch other than the hold down strap. Quickly glance to see make sure the display is still working after the cellophane is back in place. If display not working, repeat steps 2, 5 and 6 (remove cellophane, reset watch, reinstall cellophane). 7. Remove the rectangular O ring from the case back removed in step 1, or the case, and coat it with Sil Glyde silicone gel grease or similar, to retain water resistance. White grease or any grease should also work. Set the coated O ring on the inside of the metal case back removed in step 1. The O ring will eventually mate back with the O ring slot in the plastic case. 8. Using a toothpick or similar, coat the rectangular O ring slot in the plastic case with the same grease used to coat the O ring in the metal case back, to provide extra water resistance. Grease is nonconductive, so there should be no damage from shorting if some of the grease gets inside the watch. 9. Wipe hands clean and wash hands and/or use plastic gloves to avoid putting too much grease on the outside of the watch. 10. Replace case back removed in step 1. Screw in the 4 removed screws with your 5/64" Phillips head screwdriver.
Dec 21, 2010 | Casio Watches
How di i change the batteries in my Casio Pathfinder 2782
  • Choose a quiet, well-lit room where you can replace the battery in your Casio Pathfinder watch. Prepare a table, desk or other clean, flat surface where you can perform your watch repair. Put down a soft cloth or piece of craft felt to protect the face of your Casio Pathfinder watch from being scratched during the battery installation process.
  • 2
    Set your Casio Pathfinder watch face-down on the soft cloth or craft felt. Use an optical-sized Philips screwdriver to remove the four screws that secure the watch back to the body of the watch. Set the screws aside, but don't lift the watch back.
  • 3
    Slide the watch back off of the body of the watch very slowly. There are three important springs held underneath the watch back; it is essential to remove the watch back slowly to avoid losing them.
  • 4
    Lift the three springs out of your Casio Pathfinder watch using a small pair of metal tweezers. Take note of the length and placement of the springs as you remove them. Set the springs aside with the other disassembled watch components.
  • 5
    Take the black rubber protective disk out of your Casio Pathfinder to reveal an identically-shaped white plastic disk. Remove the white plastic disk and set it and the black rubber disk aside. Use your metal tweezers, if necessary, to lift out the rubber and plastic disks.
  • 6
    Release the battery strap that holds the battery in place in your Casio Pathfinder watch by pushing the battery strap latch to the left. Remove the old battery from your Casio Pathfinder using a pair of small plastic tweezers.
  • 7
    Pick up your replacement watch battery with the small plastic tweezers and insert it into the battery compartment of your Casio Pathfinder watch. Replace the battery strap and push it gently with the tip of your plastic tweezers to snap the latch in place.
  • 8
    Touch the "-" and "AC" terminals on your Casio Pathfinder watch with the tips of your metal tweezers for at least two seconds. This helps ensure that your watch will work properly once reassembled.
  • 9
    Put your Casio Pathfinder back together to complete the new battery installation. Start by replacing the white plastic disk, followed by the protective black rubber disk. Use your small metal tweezers to replace the small watch springs in their correct locations. Replace the back cover of your Casio Pathfinder, insert the four screws and tighten them with your optical-sized Philips screwdriver.
  • Best regards. Jewel
    Sep 20, 2010 | Casio PRG-40T-7 Pathfinder
    How do I replace the batteries on my Casio Pathfinder PAG40B-2V watch?
    Thank you for contacting FixYa.
  • 2
  • 3
  • 4
  • 5
  • 6
  • 7
  • 8
  • 9
    Sep 19, 2010 | Casio Pathfinder PAG40B-2V wristwatch
    Casio says open
    The open code is saying that your case isn't closed properly. Without seeing it, it's hard to tell if you opened/closed the case correctly. If you believe it is closed properly, look in your user manual and see if there is a master reset button and try that. Did you change the battery yourself or did you have a jeweler do it?
    Jun 23, 2010 | Casio Triple Sensor Pathfinder PRG60-1AV...
    Casio prt-10 and i broke the display. where i can buy lcd?
    http://www.casio.com/support/buyparts/
    You're probably going to have to replace the complete guts. Lots of these digital watches have the little buttons on the sides of the case. Those buttons press small springs which makes contact with the button on the "movement". Be careful that the little springs aren't lost when you remove the movement. It's not hard to do, you just need the right parts. A small phillips screwdrive and a sharp probe makes things easier.
    In some cases, you will need to force the stainless steel back past the rubber wrist band. These watches are nearly indestructible, so you can apply some force. Just don't apply it to the guts of the watch.
    Jun 14, 2009 | Casio G3011 Duplex LCD Watch
    Joe
    Nov 08, 2008 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
    How do you replace the watch band on a casio g-shock
    The following proccedure mentioned can be implied for replacing only resin(plastic) strap.
    If you have a spare Band, you can replace it with the help of one small four mouth screw driver and one small 1, 2 or 3 no. screw driver which you can get from any electronics/ computer hardware shop.
    Band = Strap
    You just need to remove the strap with the help of 1, 2 or 3 no. screw driver which ever you find convinent by removing the Spring Bars. After removing the strap put out spring bars from both sides as these may be used for again fixing the band.
    If you find difficulty in removing the Band, you just need to unscrew the screws on for side of the watch case and remove the ring and after fixing the strap you can fix the ring again.
    The new band can be fixed in the same way as it has been removed. You need to put the spring bar in the hollow space of strap and keeping the buckle side part of starp above the watch i.e 12 position over the space where it has to be fixed, then put one end of the Spring bar on one hole in the watch case and press the spring bar to get inside from other side (hole in the watch case). In the same way you can replace ******** other side.
    In case of any difficulty take your watch to nearest Casio Service Centre for assistance or solution of problem.
    Jul 20, 2008 | Casio Watches
    Watches Logo
    Top Casio Watches Experts
    Arturs Kalnins
    Arturs Kalnins
    k24674
    Are you a Casio Watch Expert? Answer questions, earn points and help others
