The engine runs fine, but throttle does not engage
SOURCE: 2002 honda elite scooter
All you need is a philips head screwdriver, start with the tail cover. underneath you find a 10mm bolt (socket) than 2 more screws, one obeve the foot peg and one close to the lock for the seat. An 18mm socket for the sparkplug.
Good luck, Cees
This is a great site!
http://www.ch250.net/servicemanuals.htm
SOURCE: moified 2001 honda elite-s scooter overheats on long trips.
You shouldn't need to full throttle constantly. , or at least let up on it periodically so it can dump some heat
SOURCE: Chrysler 70 HP outboard motor dies when pushing throttle
I have found that 99 percent of the time when this happens it is carb related. It is very possible that you picked a a small piece of grit or trash in the high speed jet of one, or both, of your carbs. I would be willing to bet that pulling the carbs and cleaning them will resolve your problem. I am almost positive that will fix your problem, mainly because it sounds like you've already tried everything else. I had this same problem last season, and what had happened was I left the vent open on my fuel tank, we got a shower, and I pulled just a small bit of water into the carb and that was it, she would not do anything over idle until I pulled the carbs and cleaned them. i even put the water muffs on it and let it run in the yard for about an hour thinking that it would burn the water out, but i was wrong. Anyway, clean the carbs and i think you'll be in good shape, Good Luck.
SOURCE: boat motor runs fine with the ears on. won't rev up in the water
Check the prop, may just be the hub slipping.
SOURCE: engine stalls after acceleration
Sounds like its not "un-choking" it self, that its running like its still choked like you wold at initial start up.
Disassemble it and see if u can pysically see the activation and deactivation of the choke when u apply them.
While u are at it, also make sure:
Gas is fresh?
MIx is right?
Plug is good?
Chain brake mechanism is released.?
Good luck.
