Question about Dacor Ovens
Hi I have a Dacor EO130SCH. When the display turns off to save power the clock doesnt show. Is this a problem or is it normal for this oven to do this.
SOURCE:
catriver
  • 878 Answers
SOURCE: No display
There is a safety thermostat located in the back side of this oven. When looking at the oven, from the back side, it will be located on the right side. I have a part number of 318003613. Good luck.
Posted on May 28, 2006
  • 87 Answers
SOURCE: display
Need new electronic module
Posted on Jun 14, 2007
SOURCE: My Dacor double wall oven was accidentally set to
all looked after - thanks!
Turned off the electrical breaker and the oven reset itself.
good as new!
Posted on Sep 21, 2009
blackmar
  • 235 Answers
SOURCE: the display including the
Apart from being a clock the electronic display controls the power supply to the oven. If the electronic display is dead it means that the oven won't work. Two solutions. Get the display replaced OR have a repairman bridge the back of the display unit so the oven will get power but you will have no clock or auto function for your oven.
Posted on Feb 09, 2011
  • 84 Answers
SOURCE: Random beeps, oven almost starts itself
Yes, this is certainly the touchpad. If the keypad is no longer available and you really want to save your oven. There is a solution.
http://blog.applianceboards.com/troubleshooting/obsolete-keypadtouchpanel-causing-f1f7-dont-scrap-your-ge-wall-oven/
Posted on Feb 21, 2013
I have a Dacor ERD48SCH/NG oven/range. Accidentally changed the clock time to military (24-hour) time, and now can't figure out how to change it back. How do I change back to regular 12-hr time?
Step 1 Locate the "Clock" button on the display. The display is located above the oven door. It clearly shows the time and has settings for temperature, time and cooking.
Step 2 Press and hold the "Clock" button until the time starts to blink.
Step 3 Set the time with the number pad. Ignore the colons and enter the number straight through. For example, if the current time is 10:08, just type 1-0-0-8.
Step 4 Set AM and PM by pressing the "#" button. Press "Start" to finish.
Jul 07, 2018 | Dacor Ovens
I have a Dacor ECS130 and when we turn it off the F1 code comes up and it beeps forever. i tried uplugging the membrane switch from the control/clock module (with the power off) and there is no F1...
Hi
Thanks for using FixYa. Error F1 in your Dacor Oven indicates element relay circuit failure. To resolve this issue the control board should be replaced as it has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 26, 2010 | Ovens
Dacor ECS230 oven cannot set clock. Push clock button nada.
Any display at all? If not then hunt for one of these in the wiring connecting directly to the oven control. Then try to locate the fault such as bad fan etc.2295727.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 17, 2010 | Dacor ECD230 Epicure Electric Double Oven
Dacor 48" range, double oven. ovens do not work. Letters FO appear on the display. Any suggestions?
F0 means: Clock pushbutton is stuck in a depressed position. Check clock buttons. You might need a new touch pad.
Dacor range repair in orange county, ca
appliance repair orange county, ca
Feb 07, 2010 | Ovens
PCS 130 Keypad
Dacor probably won't cover anything. F1 is either the touch pad or ERC (clock). If it stops beeping when the touch pad is uplugged from the ERC then the touch pad is the problem if not it is the ERC. Call Dacor Customer service to get a price on the parts and to voice your displeasure.
May 22, 2008 | Dacor PCS130 Preference Electric Single...
Dacor ECS230 Wall Oven Control Panel Time functions not working
Try turning the power off at the breaker for 12 hours.
I had the same problem, tried turning the power off for a few minutes but that did not fix the problem.
Leaving the power off overnight seems to have fixed it.
Nov 09, 2007 | Dacor Millennia MOV130 Electric Single...
Display 11
your control must be fried...dacor fault codes are f0 to F8 the display must be faulty..
Aug 25, 2007 | Dacor ECD230 Epicure Electric Double Oven
Double electric oven
This is actually a feature of the oven. Holding the cancel/secure button down for three seconds puts the oven in a locked out mode so that it can't accidentally be turned on. The displays say 'OFF'. Holding the cancel/secure button again for three seconds enables it for use.
Sep 25, 2006 | Dacor ECD230 Epicure Electric Double Oven
Ovens Logo
37 people viewed this question
Top Dacor Ovens Experts
Tyler T
Level 1 Expert
Jaime Hernandez
Paul Bade
Are you a Dacor Oven Expert? Answer questions, earn points and help others
