Computers & Internet Logo
A
Autry Muller Posted on Nov 23, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Huawei E5885Ls-93 WiFi router how do I set it up?
Brett Duxbury
Level 3:
  • Huawei Master 4,352 Answers
  • Posted on Nov 24, 2018
Brett Duxbury
Huawei Master
Level 3:
Answers
4352
Questions
0
Helped
1120123
Points
13423
1 Related Answer
TechyDrood
Justin
  • 2072 Answers
  • Posted on Jul 13, 2012
SOURCE: I need to buy WIFI router compatibility with Huawei EC156(Tata Photon Plus )
This is a CDMA modem, meaning it operates on the same network as phones. I'd suggest getting the Wi-Fi hub that tata offers. Guaranteed to workhttp://www.tataphoton.com/photon-wi-fi-hub.aspx
2answers
Why my phone is disconnected with wifi?
You need check your ONT or router if it has a problem. You can try to reboot them and then check again.
https://xponshop.com/collections/huawei-2-4g-wifi-ont/products/huawei-eg8141a5-ont
Sep 20, 2022 • Cell Phones
How do i connect huawei hg532f router with vsat
Connect the router to the indoor unit where the computer was connected. Connect the computer to any of the four (usually) ports on the back of the router, or if you have wifi on the computer, connect to the router that way.
A wifi connection to the router usually requires a password found on the bottom of the router. AQ direct connection shouldn't affect the works at all, should just go on like there was never a change in the source.
1helpful
How do i change my password on my LTE or router Huawei model B315s-936
1. Connect to your router Globe B315s-936/938 (via Wi-Fi using the default credentials printed at the back of modem or connect directly thru LAN cable).
2. Open your web browser, and enter 192.168.254.254 in the URL address bar to open the Globe Broadband web interface/dashboard.
3. Click Login on the upper right of website interface. Type the Globe default admin username and password. Username: user and Password: @l03e1t3
4. Open WiFi settings. For 938 modem, go to Wi-Fi Settings For 936 modem, go to Settings > WLAN > WLAN Basic Settings Set the settings to: SSID: Your Desired WiFi Name Security mode: WPA/WPA2-PSK WLAN Key/WPA Pre-shared key : "Your Desired WiFi Password" SSID broadcast: optional settings if you want to set your wifi as public or hidden.
5. Click Apply and you are done.
I don't have username and password for E8231s-2 modem
Security checklist for Huawei E8231s-1 router
To login to Huawei E8231s-1 router and change the network name and password,
  1. Start with opening your favorite browser,then in the address bar enter the IP Address http://192.168.8.1,
  2. You will now be taken to the login page where you can enter the default username: admin and password: admin
  3. Change Huawei E8231s-1 default Login and Password or reset it if you dont remember
  4. Change Huawei E8231s-1 default Wifi name (SSID) / Password.Continue reading for detailed step-by-step instructions
1.Open Huawei E8231s-1 Router IP Address Huawei E8231s-1Router Internal IP Address: http://192.168.8.1OPEN LINK
(Remember you must be at home and connected to home wifi to do this) 2.Login to the Huawei E8231s-1 Router You will now be taken to the login page where you can enter default username: admin and password: admin to complete the login process (You can simply use the copy-paste below). Voila! You are now logged in!
Default username for Huawei E8231s-1: admin VISIT MODEMLY FORUM Huawei E8231s-1 router login issues:
Huawei E8231s-1 Password Doesn't Work
Passwords find a way to not work! Or, in most cases, users find a way to forget them! In either case, look up the "How to Reset the Huawei E8231s-1 Router to Default Settings" section below
Forgot Password to Huawei E8231s-1 Router
Incase if you have changed the default username and password of Huawei E8231s-1 and forgot it, Please see "How to Reset the Huawei E8231s-1 Router To Default Settings" section below
Incase if you have changed the default username and password of Huawei E8231s-1 and forgot it, It's more like magic, I'd say! Press the reset button with a pin or something that gets through the tiny hole, and hold it for about 15 seconds! (till you see all lights flickering) Your Huawei E8231s-1 router shall be reset in no time, and you can start from step 1 in this guide to set it back up How to boost Huawei E8231s-1 Wifi and overcome connectivity issues:
1.Place the Huawei E8231s-1 in a perfect spot
The perfect spot does it all; be it romance or your router! To avail the best signal and network connectivity, make sure you keep your Huawei E8231s-1 router visibly and not facing the wall or behind the curtains
2.Find a Good Wireless Channel Instead of Auto on your Huawei E8231s-1 router
Auto channels might fail you once in a while; believe that you're smarter than the Huawei router! Find a seamless wireless channel instead of what the router finds automatically. This would ensure that your signal does not interfere with that of your neighbors.
If you're running a Windows-based PC, you can see what channels neighboring Wi-Fi networks are using.
-Press Start > type "cmd". Open Command prompt
-In command prompt type netsh wlan show all
You will see a list of all wireless networks and the channels being used in your vicinity. instead of using "Auto" for the control channel, Pick the channel that has the lowest interference
3.Check the frequency of Huawei E8231s-1
Check If Huawei E8231s-1 has dual-band, the more commonly used band would be 2.4GHz; however, switching to 5GHz would bring out better results! It depends on your device though; if you're running an old lad, you might have to switch back to the conventional.
4.Hardwire gaming consoles / media streamers into your Huawei E8231s-1 instead of wifi
Gaming consoles/media streamers work better when connected through Ethernet cable of Huawei E8231s-1; in fact, as you might not be moving your TV all over the house, why connect it to the Wi-Fi at all? The gaming consoles / video streaming devices flood the network with data. This means that if possible, you should consider hardwire (using Ethernet cable) the devices that tend to consume a lot of bandwidth. Although this can sort of defeat the purpose of having wireless network, but it can actually help your overall network speed of Huawei E8231s-1 if you can hardwire the bandwidth hogs.
5. Reboot Huawei E8231s-1 on a schedule
Here is something important to note! On schedule, folks, reboot your Huawei E8231s-1 router! Though routers are built to constantly be running at all times, simple tweak like regular power cycling (a fancy way of saying unplugging the power cord and shoving it back up) helps with most issues. Rebooting your Huawei E8231s-1 can fix Internet connection problems, improve slow moving connections and resolve wireless issues altogether. Try unplugging your Huawei modem on a quarterly basis to stay proactive (Never reset, always reboot modem)
How many SFP modules Huawei AR2220 router needs?
A Huawei switch is equal to Huawei AR2220 router only have a GE combe port, so only with an SFP module.
Huawei ascend y530 wifi not connecting
It is all in the settings.
First you have to setup your hotspot, with your WiFi router. make a note about how you call your connection and password.
Then in your smartphone, goto wireless setup and choose your connection. when asked fill in the password.
Success
Top Huawei Computers & Internet Experts
Ngoro
john h
Are you a Huawei Computer and Internet Expert? Answer questions, earn points and help others
