I feel your carburettor has a faulty float. It allows the gas to keep flowing till the engine is full or flooded. The float is made to cut the flow of gas off when the engine shuts down.
Yup float is stuck down slightly... probably a piece of old gas stuck in the gas intake or at the side of the floats pin restricting it's free movement. Using a gas stabilizer like seafoam stops this issues I have seen plastic floats that have a leak become saturated with gas and have the same issue.
SOURCE: Car starts, runs a few seconds then stops.
did you spray the maf sensor or intake hole ?if you didnt spray maf then probly not! have some one turn the key why you listen in the fill gas hole for pump noise ? sould here somthing for 2 seconds at least besure you ear is there before key is turned , also check you ecu fuse to see if it may be blown .? also you could try unhooking battery cable for 20 minutes neg side only then rehook it and try to start it! good luck
SOURCE: check engine light 2000 chrysler cirrus
if you live in the states autozone will scan the codes for free
SOURCE: 2001 toyota celica vaccum leak, po171 keeps comingon
problem is most likely your purge canister itself.
SOURCE: 1999 Mazda Protege won't start.
Recheck that the spark plug firing order or in other words the spark plug wires are in the proper order after that checks out ok, then run dry gas in the car and check all vacuum hoses there may be a vacuum leak somewhere.
SOURCE: 1990 Ford Bronco, 302 v8 (5.0), AOD Auto
is your computer inside the engine compartment? if so i am geussing it got coolant on it also and is keeping the injectors open and running the pump when it should be off.
