I think it's more likely to be a speaker settings issue. Channels are rarely individual fused these days. Generally anything strong enough to take the fuse out would kill the power to the whole unit. Speakers also tend to have protection circuits, but again these will nearly always stop all channels workings.
Most of the these multi channels systems have the ability to have speakers switched on or off, as well as adjusting the levels for them. If you read through the user manual you should find a way of activating the missing channels.
If you have lost the user manual, try looking on the Yamaha website. They should have a free PDF of it.
SOURCE: Speakers connection
There shouldnt be a problem with that at all. The subwoofer needs to be self powered. The Yamaha has a "Subwoofer Output" on the back. Just connect it there.
SOURCE: Yamaha RX-V2700 no sound from any speaker outputs
Make sure that you have the correct input signal selected.
Also, check if the sound is not muted.
If you have a multi-room speaker switch, make sure it is set correctly to main speakers.
SOURCE: I have HDMI cable from TV to RX-V365. HDMI from
the RX-V365 cannot process the audio from the HDMI input. You will also need to connect a seperate audio input (either coaxial or optical) into the relevant input in the rear of the RX-V365
SOURCE: I own a Yamaha RX-v365 and i cant figure out how
As above :
Connect PS3 via HDMI to DTV/IN, Connect HDMI from out to TV's HDMI/IN. Connect TV's Optical out to amps DTV/Optical in.
2X HDMI cables and one Optical are required.
I have the V363 but yours looks the same.
Enjoy great sound :)
OH: choose the DTV input then stereo and then dolby etc .. cheers
SOURCE: How to connect the PS3 to RX-V365 to get best
You can connect PS3 video via HDMI to receiver and from receiver via HDMI to TV. But RX-V365 doesn't support HDMI audio, so you have to connect audio separately via SPDIF digital cable. I think PS3 uses optical SPDIF, so you will need optical cable. If you can't find cheaps optical cables in your shop, you can try byuing from ebay ($1-5 max.)
