SOURCE: Flotec Shallow Well Jet Pump won't pump water
The tank is an air tank, it works like a cushon and accumulator.
Have you reconnceted the pump? If not fill the pipe that goes to the well with water. It should not drain down, there should be a foot valve that prevents the water from running back into the well. So if the foot valve is working it should not take a lot of water to do this.
Pour water into the suction side of the pump until the pump is as full as you can get it, reconnect the pump and start it up. Yes it does need to be primed
Good luck
SOURCE: diamond shallow well jet pump wont rotate, froze up.
you need to look at the start capacitor, check it with a meter, look at, and spin bearings. make sure they spin free
SOURCE: Removal of impeller and screw - is it clockwise or
The attached may be able to assit you.
http://www.goulds.com/pdf/7381.pdf
Tom
SOURCE: why wont my Jet pump shut off?
Is the little pipe that connects to the pressure switch clear?
I suggest you remove it and blow through it to make sure it is clear. If the pressure is getting to the switch, it has to shut off ... your switch should be set around 30/50 (on at 30 - off at 50)
heatman101
