SOURCE: How to turn off child lock without remote on LG tv.
hi..To do a Child Lock, follow these steps:
ur problem will be solved.. rate me!!!!
thank u
SOURCE: Child Lock Problem
Press and hold the TV/AV button and then press the red on/off button, the TV screen will become black, and any buttons on the main unit or the remote control become inoperative. If you want to switch on the TV, press and hold the TV/AV button and then press the ON/OFF button again, the TV will return to the normal TV reception
SOURCE: magnavox child lock tv
my remote control doesn't work, and i can turn the tv on because i lock to just use with the remote control. How can turn the tv on if i do not have a remote control?
SOURCE: turn off child lock
To unlock the Panel Lock,
Parent Lock, or Child Lock, follow these steps:
Note: If you don't have a remote, you may
be able to do the same thing by pressing the Menu button on the front or side
panel of your TV and using the volume or channel up and down buttons on the
TV to scroll to the Key Lock function and set it to Off.
Locate
the manual for your television. Though slightly embarrassing, accidentally
turning on the child lock to a TV is a common problem. The section In the
manual about how to set the child lock feature will also explain how to unlock
it.
Try
a few "universal methods" for unlocking the child lock. Some
televisions have a universal code built in for disabling the child lock --no
matter what your code is. A common code is "0000."
Unplug your television for a few minutes. The internal battery of the TV
is what helps remember what your code. If the TV is unplugged for an extended
period of time, it clears the internal memory, which in turn will reset your
child lock code.
