SOURCE: Microwave Comes on when Door is Opened
It sounds like a problem with the door switch or mount or the control panel. I've attached an exploded view of the oven which shows the door switches and mount. They're located behind where the door hooks go into the chassis. You can find our safety and disassembly instructions at our site via my link here: http://tinyurl.com/yzjozk If it's not switch-related, then you may have a shorted component on the control board. We repair these for customers nationwide for $32.50 postpaid in most cases.
SOURCE: remove a door on a microwave
I wouldn't remove the door myself if I were you. If you just got the microwave, it should be under a return/replace policy, or a warranty. I would recommend returning the microwave and getting a sturdier one, as you don't know if the problem exists for all microwaves in that series, and most stores don't allow the replacement to be return/replaced.
SOURCE: Over the range Frigidaire Microwave not heating. Model FMT148
This is a sure sign that the MAGNATRON needs replaced (this is what heats up the food) if every thing else works but food not cooking! 99% of time it is the magnatron!
Please rate answer!
THANK YOU!
SOURCE: My Frigidaire over the stove microwave not heating food
Hi,It is most likely the magnetron and diode that has to be replaced. This job should be done by a tech, High voltage. Magnetron's normally have a five year warranty, check your owners manual.
