My Honeywell VisionPRO 8000 thermostat does not have a 0 280 code so that I can adjust the backlight, WHY?
I have not seen this issue and the manual gives you the option of either off or dim to high upon key depress.
Manual:
0280 Backlight 0 Backlight on for approx. 8 seconds after keypress 1 Backlight always on low intensity, full bright after keypress (requires 24VAC connection).
I am sorry I can not offer any further info.
SOURCE: I NEED TO PROGRAM A HONEYWELL TH8320U 1008
Direct link from Honeywell:
http://www.forwardthinking.honeywell.com/related_links/thermostats/visionpro_8000/install/69_1894ef.pdf
SOURCE: Honeywell TH8320u Vision Pro 8000 Digital keeps calling for heat
If the thermostat is not over shooting the temperature than don't worry about it.
These thermostats are very sensitive and will turn the heat back on even before the degrees drop on the display. Often they will shut down before the display changes also. You can change the sensitivity of the thermpstat if you read the directions and change the cycles per hour to a less number. There is an installers program in there that you need to push a combiunation of buttons to get too. The instructions tell you how to do that also.
Hopefully you did not throw away the instruction manual for your t-stat.. :-)
Heatman101
SOURCE: Our visionpro 8000 thermostat has
This site has owners manuals for different types of thermostats. http://yourhome.honeywell.com/home/Products/Thermostats/7-Day-Programmable/VisionPRO+8000.htm
This site is the manual for the "VisionPro 8000". You can look up what you need, copy or download. http://customer.honeywell.com/techlit/pdf/PackedLit/69-1894EFS.pdf Roger
SOURCE: honeywell thermostat VisionPro IAQ flashing
Welcome to Fixya.
This error code implies "heating or cooling equipment missing"- on easier terms, something might be disconnected or incomplete as you may not have everything hooked up. If so, you need to go to the installer menu to make sure you have the correct settings.
Here's a user's manual just in case :
VisionPro User's manual
Thanks for using Fixya.
