SOURCE: flow restrictors
Remove the shower head from the arm and look inside the connector on the showerhead. You should see a plastic or metal piece that will either unscrew or need to be pulled out with needle nose pliers. Once that's been removed the flow should be improved.
SOURCE: Removing flow restrictor from Moen Brantford posi-temp shower he
How I remove them is take a drywall screw and screw in to the flow restrictor. Then grab it with a pair of pliers and pull out.
