SOURCE: need rubber boot key contacts
Try wdgreenhill.com for the parts. They are in England but give great service and specialize in hard to find parts.
SOURCE: I have a Casio Privia Px330. On a split keyboard
On page E11 of your manual... see the picture with two voices, one for the T and one for R... select them there.
Your manual can be downloaded here: http://support.casio.com/pdf/008/PX330E1A_web.pdf
You probably cannot "change the tone" of the two voices if they are the same voice. You should be able to transpose to different octave however.
Testimonial: "Thanks. however, with split keyboard using say right hand trombone, how do I change to right hand guitar without unsplitting keyboard?"
SOURCE: roland fantom g8, problem, The last 2 octaves do
Read page 135 regarding the note range settings. Look also for keyboard split information. You may have the keyboard set to NOT play notes in the top octaves for the particular voice you are using.
SOURCE: roland f-50 First 7 right hand whites keys appear
One of the lines in the keyboard scanner has opened up. I have an idea what it might be and it is a nasty problem involving circuit traces that are silver conductive paint on a plastic insulating base that separate from a jumper at each end of the strip that the key contacts are made by conductive rubber pills pressed down by the keys. The contact of the flexible circuit under the keys to the jumper cable can be broken by vibration. I have an EPS7 with the problem and other than replacing the whole contact strip under the keys it really has no easy solution.You should probably have a Roland shop look at this problem. If your unit has this same arrangement it is repairable only by replacing the whole key contact strip.
