Question about Franke Coffee Makers & Espresso Machines
Franke flair coffee machine won't dispense coffee.
6ya staff
SOURCE:
Anonymous
  • 4 Answers
SOURCE: Franke coffee system, always same error message ''fill water tank''
What you would have to do is take the side panel off to get at the solenoid. It is probably sticking closed and not letting the water fill into the boiler.
Posted on Mar 21, 2009
frankecoffee
  • 29 Answers
SOURCE: our franke flair coffee machine keeps saying
this is usually due to the overtemp device activated on one of the thermoblocks, an engineer will be required to replace this item,
Posted on Nov 19, 2010
raj somaiya
  • 5370 Answers
SOURCE: Our Franke Flair is well cared for! Has been
Remove the water tank out.Then turn off the machine.Then turn on the machine.It will give message, water tank out or no water tank.Insert water tank then see.If it go further "please wait". But if its still not going beyond please wait, then its internal fault.The temperature thermostat is stopped working or its not heating inside.So the unit is just displaying please wait.The thermostat and heating element has to be checked and replaced.------------ This will help.Thanks.Helpmech.
Posted on Jun 02, 2011
Richard Brooks
  • 242 Answers
SOURCE: Hi, my Franke Flair does not respond when I push any of the buttons to make coffee, water, milk etc. it just displays the 'SELECT PRODUCT' message. The rinse, clean and descale buttons all work.
Unplug unit to reset the settings completely...If you have the same problem call manufacturer to save time...
Posted on Apr 05, 2015
mitchgray
Mitch Gray
SOURCE: I have a franke flair coffee machine when you
Does any one know how to remove the lid of a franke flair coffee machine
Posted on Apr 26, 2015
No milk and steam dispensing from Franke Flair coffee machine
I am a Franke technician. After and possibly during the descale, because probably you haven'nt done it in a long time, steam was able to escape through the fittings as the limescale damaged the silicone rings beforehand. The steam damaged the klixxons or the thermoblock itself. You will need one of us unfortunately....
Feb 17, 2018 | Franke Coffee Makers & Espresso Machines
How to remove the lid on a franke flair coffee machine
If you are refering to the main cover! firstly the hoppers have to be removed. then the metal plate on the top(cup warmer) secured with 4 x t15 torx screws. once the plate is removed the main cover is secured with 4 oval headed screws 2 of them located under the plate just removed. the other 2 are located under the adjustment rings for the grinders. the main cover then can be removed. there are 2 electrical connection plugs that have to be disconnected .
Apr 26, 2015 | Franke Flair Espresso Machine with...
My franke flair coffee machine will not power up
the two main reasons for this are the on off switch located on the back of the machine is switched off. the other is the flap to the grinders is not correctly fitted. other than this an exporative visit by an engineer may be required. there are two mains fuses situated by the cable inlet behind the rear panel.
Apr 26, 2014 | Franke Flair Espresso Machine with...
Franke flair trips the electric when turned on
It might be good idea to disconnect the coffee valve and switch on machine as it's 230v and might be shorted and tripping and blows fuses.If it is then replace brew valve.
Apr 13, 2014 | Franke Saphira Espresso & Coffee Maker
Franke flair
Where can I buy new seals or a whole new drop tray please
May 15, 2013 | Franke Flair Espresso Machine with...
How can I get different size lattes and cappucinos with my Franke Flair? all it gives me is a shot size serving...
enter programme button.push and hold for 5 secs.machine will show def product. press programme again to confirm.select product comes up on screen.press the product you want to adjust eg espresso.now use the + and - buttons to scroll through the espresso setting. if you want to adjust anything in the settings, you need to press programme. then make the adjustment with the + and- buttons then press enter when finished the actual adjustment .once finished with the espresso and happy press exit button.repeat the process for the next button. you can down load a manual at franke .com
Aug 17, 2010 | Franke Saphira Espresso & Coffee Maker
If you need a Franke trained coffee machine engineer to repair, service or for training, i can be there within 24hours, Email me for any questions great prices! 50mile radius of CV21 3SH
Hi
I have just bought a Franke Flair coffee machine second hand. It looks like new and the seller said it was in good working order - however it does not have the grinder blocker and I think we need one. I wouldn't mind also getting the once over from an expert and then maybe some kind of ongoing contact should we have problems with it. What are your rates?
Jun 15, 2009 | Franke Saphira Espresso & Coffee Maker
Coffee Makers & Espresso Machines Logo
Top Franke Coffee Makers & Espresso Machines Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
jonathan Hanson
Level 1 Expert
Are you a Franke Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
