Supersonic TV SC-2211 make sure on tv air then channel search
SOURCE: supersonic sc-25dvd
Call 1-800-remotes, i used to work for McMahons furniture and when a customer lost a remote we would get them through these guys and the best but is if they dont have it they will make one for you.
f.y.i. it's a little spendy but they ALWAYS WORK!
SOURCE: tv won't scan channels when connected to cable tv
Hello
The first thing is to try going in the tv's menu
It should be similar to this:
Menu>setup>channel setup
once you find something similar, run the channel setup and it should add in the channels
If that doesn't work, screw on the cable wire, unplug the tv for a good few minutes, then replug the tv and it should automatically scan
Hope this helps
-Chris
SOURCE: Channel Scan on my Philips 26" TV only finds the local channels.
Hi.
you should go into your tv's setup menu and go to the tuner settings and make sure it is set to CATV (cable tv) and not Antenna/Air also splitting a cable to many times can cause the signal to weaken and gain a lot of noise/distortion that could be an issue that can only be solved by having the company come to the house and do a test ALSO when your in the tuner menu in under your tv's setup menu try adding a non local channel manualy and then see if the tv will tune to it, if so then you might have to add them manually at the worst... my guess is that it is not set to CATV/cable tv hope this helps and if not i hope someone else can.
SOURCE: Olevia is not picking up my cable channels
pick up the remote turn on tv....press menu...setup....tv....then channel scan....(note your tv should also be on cable broadcast not air)...hope this is helpful
SOURCE: no tv signal on my olevia 232-s12
cable or Ant.. ? after the scan if there is no channels found (0 digital, 0 analog) then try with cable or Ant to see if any of them work.. if they still don't pick up any channels and the whole yellow progress line goes across.. then it sounds like the tuner on the tv is bad.. and the tuner is part of the main-board so the whole main-board will have to be exchange or repair.. contact Amergence technology they are a 3rd party repair center that service Olevia TV's and they will be able to give you an idea on the repair cost..
<<< Amergence Technology number is 866-965-3842 >>
