Water Heaters Logo
N
Nghiem Nguyen Posted on Nov 20, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is noritz code 67 and how to fix when it appear?
Ron Denwood
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 21, 2018
Ron Denwood
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2257
Points
5
Check the owner's manual for your _specific_ Noritz model to see if that error code is listed. You should be able to find the manual with a google search. If the error code is not listed in the manual, contact Noritz America at 866-766-7489.
Dave McNeely
Level 2:
Habit-Forming:
New Friend:
  • Expert 45 Answers
  • Posted on Nov 20, 2018
Dave McNeely
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
45
Questions
Helped
28885
Points
199
Here is a link to all the Noritz error codes. There is NO Code 67. https://inspectapedia.com/heat/Noritz-NCC199-Error-Codes.pdf
Noritz: Tankless Water Heater. I have an error code 99 on my Noritz tankless. How do l reset it please?
Remove the bird's nest in the flue.
The 10, 59, 90 and 99 error codes indicate that a Noritz heater has experienced a combustion abnormality. In most cases, it is the result of an obstruction in the heater's flue. Examine the flue to see if it is blocked by debris and clean if necessary.
How To Resolve The Seven Most Common Noritz Tankless ...
Noritz https://www.noritz.com > Blog
Nov 16, 2015 - This error code involves a breakdown in communication between two tankless water heaters using the Quick Connect Cord. It can occur when more ...
Troubleshooting Noritz Tankless Water Heaters and Error Codes
home-water-heater.com https://www.home-water-heater.com > noritz-error-co...
Error code 90 and 99 ... Action: Check for the obstructed venting, improper gas burning (flame shape and color change). Ensure the water heater gets the ...
Error Codes for a Noritz Water Heater - Waterheatertimer.org
Noritz Tankless Water Heater - Error Code 20 - Priority Light Flashing - EZ98DV
Error Code 20 on a Noritz tankless water heater (model EZ98DV) is typically associated with an issue with the "priority" function, which is a feature that allows the water heater to prioritize certain uses of hot water over others.
When the "priority" light is flashing and error code 20 is displayed, it typically means that there is a problem with the priority function and it needs to be reset.
To fix this issue, you can try the following steps:
  1. Turn off the power to the water heater by turning off the circuit breaker or removing the fuse.
  2. Wait for about 10 seconds and then turn the power back on.
  3. Press and hold the "priority" button for about 5 seconds, until the "priority" light turns off.
  4. Turn the water heater back on and check to see if the error code has cleared and the "priority" light is no longer flashing.
If the error code 20 still appears and the priority light is flashing, it's best to consult the manual or a professional technician to diagnose the problem.
It's important to note that the error code 20 can also be caused by other issues such as, faulty thermistor, faulty thermistor harness, faulty PCB, etc. So, it's best to get it checked by a professional.
Noritz water heater error code 99
MAke sure your flu is not making any 90degree turns. Use 45degree turns only. Error 99 is a combustion error. Usually referring to a blocked/obstructed flu. That said, a flu wit a lot of 90degree turns can act like restrictions to tankless heaters. If the flu i straight and clear, then you have a burner problem. Somethign you want Noritz to deal with.
I have a Noritz tankless water heater (model n-132m). I am getting an error code of 71. What does that mean?
The Noritz Manual shows fixed for the following error codes:
11
21
90
99
For all other codes this is the recommendation:
Contact our sales agent if:
• Any other error code appears.
2answers
What is code blinking 20 on noritz tankless hotwater heater N_069M
The error is a HIGH LIMIT THERMAL ERROR. That means Calcium buildup has appeared in the unit. It is also called scale. To clear the error you have to power it off. That is done by the circuit breakers. You should descale the unit first though.
Code 125 on my Noritz tankless water heater
Call noritz
(866) 766-7489
http://www.noritz.com/contact-us/
Don't buy a tankless water heater.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
What does an error code 66 mean on a noritz Model N-0751M
http://www.noritz.com/u/pages_from_field_manual_2010_12_09_pdf__adobe_acrobat_professional.pdf
The Noritz field manual says that error code 66 is Bypass Water Control Valve failure. Call support at 866-766-7489 with your model #, serial # (both on the unit face plate), date of purchase, to see if the valve can be replaced under warranty.
11helpful
2answers
Noritz tankless water heater not producing hot water
I called Noritz error code 16 is a overheat problem. Noritz say's to flush your coil with vinegar or CLR.
Use a small pump to recirculate the CLR or vinegar through the system for 45 minutes and flush with fresh water. This worked for me.
Top Noritz Water Heaters Experts
Paul Carew
john h
Are you a Noritz Water Heater Expert? Answer questions, earn points and help others
