Quite a few brands of TV are actually programmed to do this. A lot depends on what kind of service you have. Cable? Satellite? Antenna? In your setup program for your TV (you probably have a paper guide) you will need to select what kind of service you have and that will depend on what kind of connection you have put your service into. TVs are close to plug-n-play but not quite. Your setup program will get you there.
SOURCE: no audio on some hd channes
Try pressing the MTS button on your remote while on the channel that does not have audio and select stereo. Most likely this will be set to SAP (secondary audio programming) and there is no SAP programming on that show. This is not something that could be avoided. It was during the channel scan, it locked in the SAP audio broadcasts for some reason.
SOURCE: 27F520T RCA Truflat, won't scan for channels, auto or manual, only blue screen, no channels on tv
You need to replace the microprocessor. GoodLuck there is 52 pins to unsolder and resolder a new one. The price for the chip may bee about $35
SOURCE: Dynex 32 Inch Installation Problem
Hi I Just Bought A Dynex 32 Inch HDTV. I Did A Auto Scan And It Didnt Pick Up Any Digital Channels? Am I Suppose To Have An Antenna Or Digital Box? How Do I Get Th Channels To Come In?
SOURCE: When setting up a new
you need to select cable from off your remote and run the auto scan.even if it says you does not need to run auto scan still run the auto scan.good luck.
SOURCE: Will not set tv channel to 3...keeps telling me to please run channel auto scan
You can do it manaly.
