SOURCE: no heat when i switch oven on
There is no doubt that it is the element that has failed, so all you need to do is replace the fan oven element.
If you can see a removable panel at the rear of the oven ,remove that, and you should see the element.
Remove and replace.
If ther is no removable panel then you will have to access it from the rear of the oven cabinet.
Plz rate my solution.
thanks,
SOURCE: bottom oven not working
A tripped breaker or blown fuse on an electric oven or cook-top, combined with an element that has stopped working, is usually a sign of a shorted, then blown (if the fuse or breaker no longer fail) element.
If you know how to use an ohmeter, you can pull the element, disconnect the wires from each end, then measure the resistance between each end of the element, and each element to the outer sheath.
A good element has just a few ohms of resistance between the wire connection points, and infinite resistance from the wire connection points to the outer sheath. Any readings other than that means the element is bad and need's to be replaced.
SOURCE: replacing electrolux eob944 fan oven grill element
...If you can help me to remove the grill element from my EOB944, I will be able to tell you the wirings.
SOURCE: My oven burns everything.
Use a 'oven thermometer' in the oven and determine the 'actual temperature' in the oven. Your knob setting is off (not calibrated) and the oven is hotter than the control knob setting.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: delonghi esf461st built in fan oven. No operating
The setting with the fan is fan only function.
The setting with the fan and circle is for fan and element for heating the oven.
Please rate my solution.
Thankyou.
Testimonial: "thank you very much. Now fully operational."
Where can I find out how to apply these settings please.what do they sugget for baking cake
