Toys Logo
Gerry Matthews Posted on Nov 20, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Holiday express train works, lights work but sound does not work
Brandon SPCleister8102 Leister
Level 2:
Habit-Forming:
New Friend:
  • Expert 113 Answers
  • Posted on Nov 20, 2018
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
113
Questions
7
Helped
28679
Points
420
Whats the A. Brand B. Model C. Where did you get it
5 Related Answers
Bob Moody
  • 14 Answers
  • Posted on Dec 16, 2009
SOURCE: New Bright Holiday Express Animated Train - figures do not move
Make sure you the wheels on the cars are actually rolling and not sliding (being drug down the track) Most of the animation is down mechanically as the set moves.
Anonymous
  • Posted on Dec 19, 2009
SOURCE: Holiday Express Train Set
We struggled with this just today...finally figured out that you have to twist the small piece right behind the bell on the top of the locomotive.
Testimonial: "Thank you! Now... how do you keep it on the track? :O)"
Anonymous
  • 5 Answers
  • Posted on Dec 24, 2009
SOURCE: an electricalroblem with Holiday Express train
This train set is very particular and getting it to work each Christmas is a family tradition in frustration. First you must make sure that all the pieces of track are connected properly and that the track is perfectly symmetrical and flat. We double-check the battery positions every year and find one in wrong. There are + and - signs, but they're hard to see; use a flashlight. There is a black toggle switch below and behind the red stack that toggles forward (to make the train go forward) and backwards (reverse); straight out perpendicular to the train is the "stop" position. Also, you have to start at a stop/switch station. One other note: behind the red stack, there is a smaller black stack. If you turn this, you can make smoke come out of the stack. I think I remember someone suggesting a drop of cooking oil. Hope this helps!!! Hope you get it set up for Christmas!!!
Anonymous
  • Posted on Dec 28, 2009
SOURCE: My New Bright Holiday Express train set is 10
Make sure your track is clean. take a green scrub pad and rub the track to clean off any tarnish
Anonymous
  • Posted on Dec 31, 2009
SOURCE: No power to track and/or train. Power to Holiday Express Train
Power enters through the tender. You must have the tender and the engine both on tracks and linked with electric cable.
New Bright Holiday Express train No. 380 won't run or even light up
My 1996, #380 New Bright Holiday Express stopped working. When l pushed the on/off button on the control panel, the light was green but it won't light up, make sound or run. Bought another control panel but still doesn't run. All connections are plugged in properly, engine and cars are properly on the track, checked the brushes-great... please help! Thank you!
Holiday Tradition Express, engine tender not working. Contacted Lionel Trains, they have no replacement parts or service available.
Best bet is to search the internet for Lionel replacement parts. Try to include as much information in your search.
Remote is not working for my Lionel Holiday Tradition Express Train with new batteries. Any suggestions?
I rewired my train this weekend..it now works on my outdoor setup....I found that the circuit board inside the engine had a blown capacitor and the power transitor was fried. I by passed the engine board found that it only would run backwards....went into the tender and taped into the power from tack bypassing the rectifer... By the way the engine does not start up when one uses the remote...there is a 20 second delay before starting
1helpful
2answers
On my Lionel Holiday Tradition Express the handheld remote works yet with the train will not respond. All connections have been cleaned and that is not the problem. I did notice that the wheels on the...
the train does not run in daylight.....when one places the remote over the engine protecting the senor from sun the engine will start 10seconds after the sounds...I was very disappointed that it would not run in daylight. I'm looking for a method to rewire the system to work in daylight....maybe bypassing the control card.
Each yr my New Bright Holiday Express train gets slower and slower the longer it runs. Finally it just stops. Every thing else seems to work: lights, etc.Train shop specialist say its the engine, not the...
check the electrical current to the trans former , then check the out put from transformer, may not be getting adequate electricity flow to operate , and if you continue to operate under required current , it may damage engine and or transformer , gd luck
2answers
I bought the set last year of holiday lionel trains g replaced batteries, have light on remote and noise from engine but no movement? any ideas
If all cars are not properly on the track, the engine does not have enough power to pull the cars. Try with engine and coal car only to zero in on cause.
2answers
WE are trying to get our lionel holiday train going. Is there an on/off switch on the train? the part that goes on the track is lit up but when we puch the remote control with train on the track nothing...
There is no on/off switch. Remote will give no indication of working. Try putting engine and coal car only and try. I have had this train set for two years and the remote tends to work whenever it wants.
4helpful
Top Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Toy Expert? Answer questions, earn points and help others
