We cant see your screen, so answers are very hard lacking photos of failing screens.
NO PC stated at all just Laptop ,it has model name and number.
NO OS stated, just windows, (XP?) the virus magnet XP?>
yes remove the huge battery first. run on AC PACK only , good now?
yes, clean PCs vents of all lent.
are you running said laptop on blanket blocking air vents, bad that is . do not do that.
funny screen graphics, and worst stalling is what to diagnose.
try this big battery out.
turn on PC, and go to the first BIOS screen using the BIOS hot key that is in your manual, I cant tell you, as no PC stated.
The if this screen looks good for hours on end., the Hardware is mostly ok.
if this fails.
does the fan blow air,? as it must for sure if it overheats the fan blows faster on all PCs like this.
all PCs overheat if not serviced (cleaned)
all do.
if fan dead
if fan can't speed up, due to lint packing IT.
vents clogged, and more.
first run with that battery pack larger removed, on AC only.
see if it run on AC , you can do that forever if you want,
if PC fan acts up say so or if dead.
my guess to is the GPU chip gets too hot.
The CPU self shuts down at 90C, by the magic of Intel Inside.
(or AMD inside )
SOURCE: My Sansa m240 freezes at the title screen.
I have the same problem. I called tech support 1-866-726-3475 and they talked me thru several cures. None of which worked. My unit is about 8 months old. After trying all the options, they gave me a rma number and are sending me a replacement. I think they have had some trouble with this lot of players, they were very nice and it took no prodding from me for a replacement! Good Luck1
SOURCE: While playing a game, the screen freezes and the
The freeze ups normally happen before the red lights of doom and they are caused by the GPU and the CPU getting too hot and the soldering snaps off so they lose connection.
If you stop the heat build up you will be fine.
You can do this yourself using a good repair guide or you can send it in and they will fix it for you.
SOURCE: lenovo laptop using windows xp boots up, freezes
hi there, its a system glitch of windows. i experienced that problem before. heres the solution for that issue. boot your computer to safe mode. once you are in safe mode click start menu then all programs then click accessories then system tools then system restore. choose a date where your computer is working fine and restore the computer to that date.
please let me know if you need more help.
thanks
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
SOURCE: palm is non responsive. It won't turn off.
Take the protective cover back off then try resetting it if needed. If the cover is not the right size or isn;t on in the right place it will do this. Usually it will just be one corner that gets stuck under the frame edge and then the digitizer pad thinks that you are holding down the stylus there and locks up after a while. Or it flips pages and so on.
Hi Gogo , I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
the PC has name,
full name , please share that first.
so helpers can answer with clarity.
even on topic.
Id say off hand blind, OVERHEATING or the big battery is shorted(remove it)
see all these off the wiki
what PC is it?
100 Series laptops (ideapad)
100S Series chromebook (ideapad)
11e Series Chromebook laptops (ThinkPad)
11e Series laptops (ThinkPad)
13 Series Chromebook laptops (ThinkPad)
13 Series laptops (ThinkPad)
2-in-1s Series Laptops (ideapad)
300 Series laptops (ideapad)
500 Series laptops (ideapad)
700 Series laptops (ideapad)
A Series laptops (Lenovo)
A Series laptops (ThinkPad)
B Series laptops (Lenovo)
D Series laptops (ideapad)
E Series laptops (Lenovo)
Edge Series laptops (Lenovo)
Edge Series laptops (ThinkPad)
G Series laptops (ideapad)
Helix Series laptops (ThinkPad)
K Series laptops (Lenovo)
L Series laptops (ThinkPad)
LaVie Series laptops (Lenovo)
Legion Series Laptops
Lenovo Chromebooks Series
Lenovo Flex Series Laptops
Lenovo M Series laptops
N Series laptops (ideapad)
N Series laptops (Lenovo)
P Series laptops (ideapad)
P Series laptops (ThinkPad)
S Series laptops (ideapad)
S Series laptops (Lenovo)
S Series laptops (ThinkPad)
T Series laptops (ThinkPad)
Twist Series laptops (ThinkPad)
U Series laptops (ideapad)
U Series laptops (Lenovo)
V Series laptops (Lenovo)
W Series laptops (ThinkPad)
X Series Chromebook laptops (ThinkPad)
X Series laptops (ThinkPad)
X Series Tablet laptops (ThinkPad)
Y Series laptops (ideapad)
Y Series laptops (Lenovo)
Yoga Series Chromebook laptops (ThinkPad)
Yoga Series laptops (ideapad)
Yoga Series laptops (ThinkPad)
Z Series laptops (ideapad)
Z Series laptops (Lenovo)
surely you can post what you own.
"yes, I know, Don't call me "surely" hehehe
