SOURCE: SanDisk Sansa e260 MP3 Player
To reset the player hold in the power button for at least 20 seconds, when you release the button the player should restart on it's own. If it doesn't then try again holding the power button for a little longer. If for some reason the player becomes unstable and resetting doesn?t resolve the issue, then try the Sansa Connect Recovery Tool which will clean up your player and restore it to factory settings. You can download this tool & get instructions on it's use on the following link: http://www.sandisk.com/Retail/Default.aspx?CatID=1532 Please update the question & let us know if the information given was useful to you - Good Luck!
SOURCE: frozen ipod
Here you go :) Please rate me on wether or not this article resolves your issue
Last Modified: January 28, 2009
Article: HT1320
Old Article: 61705
Summary
Learn how to reset or restart iPod following a freeze.
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.
When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time are preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
SOURCE: my visual land v-touch 8gb mp3 player is frozen and wont turn on
take the battery out or hit a reset button if its avalable and turn back on after 30 seconds
SOURCE: Sony Walkman NWZ-S618F MP3 Player - Screen display not working
I Have the same problem, but mine has vertical lines running on the display, try contacting sony support
SOURCE: My Sylvania SMP2012 is not playing music
it turn play the music for 1 second dont play again
