SOURCE: E013 - 0002 Do I have to replace the DC controller PCB Board?
clean your waste toner pipe by using a vaccum you also haveto hit it to break up any hard toner build up replasce the bottle take machine off then on again
SOURCE: Canon Gp200 Error Code E000-001
I looked up the e000 and it said it's for the fuser using not heating up and 001 error code and it is that the fuser unit is overheating. So seem to me you have a bad fuser unit.
SOURCE: I have an event code of 54.11.00
When the above code appears the most important thing you want to do is you have to calibrate the device and see if that helps. If the error messages are with the most recent page count, then the dc controller is defective and it needs to be replaced.This is the common fix for this code problem.
Thank you
SOURCE: I need canon gp 405 Service manual that contain
this site have service manual which contain most of requested bits, including how to and what to do. it is not for faintharted do... :-)
http://www.scribd.com/doc/16699855/Canon-GP405-service-handy
if you find my answer helpful, please rate it, thanx!
