On the 1998 Evinrude 15hp outboard, the air/fuel mixture is controlled by the carburetor. The carburetor is preset at the factory to provide the correct air/fuel mixture for normal operation. If you are experiencing performance issues or rough idling, it is best to take your outboard to a qualified mechanic for proper diagnosis and adjustment.
However, if you still want to adjust the air/fuel mixture yourself, here are the general steps:
Note: Adjusting the air/fuel mixture can have a significant impact on engine performance and should be done carefully and in small increments. It is important to use the correct tools and take appropriate safety precautions when working on your outboard. If you are unsure about any aspect of the process, consult a qualified mechanic or refer to the manufacturer's manual for specific instructions.
SOURCE: Evinrude, 15hp 4cycle outboard, 2000 model - starves for gas
hi obviously a fuel fault someware / when motors are winterised the fuel system is usualy emptied, this causes gaskets and diaphrams to dry out and split try it with the tank filler off /replace the diaphram in the carb and i am pretty shure that will solve the problem /nb / as this motor has stood for a time and does not do much work /outboards love work check the water pump impellor and put a spoonful of oil in a full tank of gas hope this helps merlin v12
SOURCE: how to remove the twist grip on 15hp evinrude outboard motor?
Fix Tiller Handle on 15hp Evinrude - YouTube
? 2:02
www.youtube.com/watch?v=dl0b7WFKsjc
Mar 30, 2011 - Uploaded by Budnipper82
Evinrude 15 HP gear removal - Duration: 9:11. by kodibass 7,404 views. 9:11. Repairing an Evinrude 9.9 ..
