The most common remote codes for Sanyo televisions are 1045, 1062, 1095, 1380, 0049, 0097, 0110, 0004, 0268, 0012, 0108 and 0180. Many universal remotes can be programmed with Code Syncing, which does not require the input of a code.
To program a universal remote using Code Syncing, switch the TV on and press the TV button on the remote. Now press and hold the Code Search or Program Search button until the LED on the remote begins to flash. Press the Power button repeatedly (leaving 1 to 2 seconds in between presses) until the TV switches off. Immediately after the TV switches off press the Enter or Program button. Switch the TV back on with the remote, and check that all of the applicable buttons (such as Vol+ and Vol-) operate correctly. If the remote control doesn't have a Code Search or Program Search button, Code Syncing may still be an installed feature. To program a remote that doesn't have a designated Code Syncing button, without using a code, firstly switch the TV on. Press the TV button on the remote. Now press the Power or TV button repeatedly (leaving 1 to 2 seconds in between presses) until the TV switches off. Press the Power button again to switch the TV back on. Now check that all of the applicable buttons operate correctly.
SOURCE: Masterplug tvrc4n 4 in 1 remote control/sanyo
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): We could not find an exact match, we think this code will work. 10054 Setup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
SOURCE: i need codes for philips universal remote control
I have a phillips universal remote, that I brought in Georgia. I have lost the instructions for programing.
My television is Emerson and I need the codes and instructions. Please help.
SOURCE: Sanyo Vison model CLT2054 - three years old.
clt2054 Sanyo vizon 20" TV
At power on my screen blinked on for a second, then went black for a minute or so, then blinked back on, this repeated. I noticed the external 12 volt dc 5 amp power supplys green light blinked on & off with the TV but it blinked off just before the TV did, indicateing that the problem was a power supply problem. Then I put the PS transformer up to my ear and could hear it buzz as it powered on each time. The buzz increased in frequency rapidly then stopped as the internal heat fuze/thermister er something, shut it off for a minute untill it reset. A person could buy a new Power Supply transformer for $14 to $40, or could try to fix their PS. But I simply hooked it up to a 12v car battery & the TV worked. On the back of the transformer is the pinout for the 12v 4 prong plug that goes into the TV. On the TV the bottom 2 pins a 12v+ & the top 2 pins are 12v negitive. Nails with the burrs filed off fit into the sockets, a strip of thin card board between the pos & neg nails for an insulator, & aligator clip jumpers on them to the battery got me a working TV. So I now know it was a power supply problem. I could follow the advice of others on this great FixYa site & try to fix my PS capacitor problem ? Or buy a new PS, or just put the TV in my 12v veggie oil diesel magic buss, er camper thingie. AND please don't send anyone $19.99 for free advice.
I hope this helps someone in somehow.
bitdog
SOURCE: CODIGOS PARA EL DAEWOOD TV DEL CONTROL REMOTO RCU403A
NO SE EL CODIGO DE MI CONTROL REMOTO RCA 403, PARA MI TV MAGNAVOX..... AYUDENME, PLIS
SOURCE: Which power cord for sanyo clt 2054 lcd 20" tv
I found it on amazon. here UpBright New Global DC 12V 4 Pin DIN AC DC Adapter For Sanyo CLT2054 LCD... . I hope I have helped. Cheers
