Question about Frigidaire Kitchen Ranges
I have a Frigidaie 40" electric range (FGEF4085TS), When I use the self clean for min. 2 hrs the oven stops working. Is there any recalls on this or anything I can do to reset the oven?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 37 Answers
Do not use the self clean, it gets the oven way too hot and the oven won't work while it is cleaning. On our oven we put a piece of black electrical tape over the self clean button and told everyone in the household to not use it ever.
Posted on Nov 19, 2018
SOURCE:
  • 1314 Answers
SOURCE: Whilrpool Self Cleaning Range Door won't unlock
try this 1. Verify error code by pressing and holding CANCEL/OFF key for 5 seconds.
Momentarily (less than 5 sec.) press CANCEL key again to remove error code
display.
2. Press and hold any key for 1 minute until F2 E0 code is displayed.
3. Cancel F2 E0 error code.
4. Program and start the clean mode. Observe to see if door locks. If it does not,
inspect the locking mechanism from the solenoid to the latch pawl and door to
find the cause of the problem. If the door is not locking, then 1 minute from the
start of clean, the F5 E1 code will again be displayed. Steps 1 through 3 will
have to be repeated before another clean can be started.
5. Once any mechanical problems with the latch mechanism have been corrected,
program and start a clean cycle (after, if necessary, clearing F5 E1 error code)
to ensure proper operation of the door lock. Immediately cancel the clean mode to observe proper operation of door unlock
Posted on Feb 12, 2008
Agent Matt
  • 8 Answers
SOURCE: Unlocking Oven controls
According to the manufacturer's website you should only need to Press and hold the "Lock" key for 5 seconds. A single tone will sound and the "Loc" will disappear off the display.
This is the link to Whilpool's website and to the manual.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%209761079.pdf
Thank you
Agent Matt
Go Ahead. Use Us.
Posted on Apr 07, 2008
aborcass
  • 2651 Answers
SOURCE: I was trying to use
F5 - E0 F5 - E1 and E2 Check door/latch switch Replace switch if defective
Posted on Jan 11, 2009
SOURCE: I have no manual and do not know how to use
The latch wouldn't go all of the way over. I pushed it over until the blinking light went off. The latch doesn't seem to catch but I did get it to work. Thank you for your help though.
Posted on Apr 10, 2009
SOURCE: dacor range (oven)does not work
I have had the same problem for ten years. After a few years of the tech coming out everytime
I self cleaned, I had him show me how to reset, and he also gave me a new reset gizmo in
case that doesn't work. As for resetting, the top plate on top needs to come off and then you'll
see the gizmo with a dark red reset button that is attatched to the floor of that top compartment, which I leave unattatched for easier access. Push button down, of course turn off the electrical power to oven before doing all this. Works everytime.
Posted on Jun 14, 2009
I can't find a button marked self clean on my crosely oven. Can you send me a picture of which button I use and instructions for self cleaning. Thank you Kellyann Waye
1. move door to locked position
2. Press self-clean pad.
3. press up or down to select clean time (it will flash 3:00)
4. if you wish to delay the start of cleaning press a. stop time b. press the up button on pad to select the time of day then press clock and time of day will reappear. Press stop time pad to recall the time you set.
5. When the oven turns on the oven on indicator will light. Internal lock will engage and door cannot be unlocked.
6. About one hour after the clean cycle ends, the lock indicator will turn off. The oven door can be unlocked and opened.
** to cancel press cancel.
Hope that helps!
Jul 13, 2011 | Crosley CE35111AA Electric Kitchen Range
I have a kitcheaid gas range. just used the quick, self-cleaning cycle/2 hrs. 30 mins./went out came back no display and door will not open/
The temperature cut-out thermostat at the back of the oven has failed. You will need to pull the oven out and remove the back panel. Thermostat should be at the top in the middle. Once replaced oven will be back to normal.
Feb 26, 2011 | KitchenAid KGSA906PSS Gas Kitchen Range
Frigidaire CFEF372BC2 electric range - oven door won't unlock after cleaning cycle
Hi .The oven door will not unlock until it cools down despite the cycle being finished.If it has not opened in a maximum of 1 or 2 hrs then oven sensor failed during self clean cycle and will have to be replaced.Try restarting self clean to unlock door .If not you will have to do the old coat hanger trick or manually move the lock mech. from rear,sensor cost $30-40.Hop this helps .Please rate my response :)
Dec 13, 2009 | Frigidaire FEF336BC Electric Kitchen Range
How to turn off self clean oven Jenn air slide in older model after it is done cleaning
the self clean cycle will run for 2-3 hrs and the door will remain locked for another couple hrs while cooling let it finish and wait till the next day basically if it still wont open (sorta common) the door lock assy needs replacing.
Oct 08, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Oven shuts off when the door opens
Turn breaker off for 5 mins. then turn back on, this will clear the memery and take it out of self clean.
Please rate solution
Sep 05, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
I have a Whirlpool electric build in oven with self-cleaning feature. It is about 8 years old and we just used the self-cleaning feature for the first time last week. The oven was not that dirty, but...
Your thermal fuse or TOD mounted to the back of the oven went out during the self clean,it shuts off the power to the elements.
 The oven must be removed from the wall to change this.
Aug 31, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
I have no manual and do not know how to use self-cleaning function. I have a Hotpoint electric self-cleaning oven. I can't find a manual and the only model number I can find is on the door PLT083-2. The...
Apr 09, 2009 | GE Hotpoint 30" Self-Cleaning Freestanding...
Frigidare Self Clean Oven
I JUST CALLED FRIGIDAIRE AND GOT INSTRUCTIONS FOR SELF CLEANING:
1. TAKE OUT THE RACKS UNLESS YOU DON'T MIND THEM TARNISHING
2. TURN THE "SELECTOR" AND/OR "OVEN" DIALS TO THE LOCK (OR CLEAN) POSITION
3. PRESS THE "COOK TIME" BUTTON
4. SET THE CLOCK TO 2 OR 3 HOURS (I.E., "2:00" OR "3:00"), DEPENDING ON HOW DIRTY THE OVEN IS
5. PRESS "START" BUTTON
6. YOU WILL HEAR THE MOTORIZED LOCK MOVE INTO PLACE; WAIT ABOUT 30 SECONDS, THE DOOR SHOULD BE LOCKED AND CLEANING WILL BEGIN.
7. CLEANING WILL STOP AFTER THE TIME SELECTED (I.E., 2 / 3 HRS) AND THE DOOR SHOULD AUTOMATICALLY UNLOCK
Sep 30, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Clock on Model F120 stove Serial 53031577
just set the clock as if to clean , just remember to turn oven off in 2- 3 hrs wait 30 min then before trying to open dr.
Dec 17, 2007 | Jenn-Air SVE47100 Slide-In Electric...
Kitchen Ranges Logo
48 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Marvin
Marvin
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
