K?rcher UK Good afternoon
The WV does not have a serial number - Please input "000000" Into the "Serial Number" box. Please note - the registration is not validation of your warranty. Your proof of purchase (receipt) will need to be provided, should you have and problems with your machine.
We hope this helps, If we can be of any further help, please do not hesitate to contact us.
Kind regards,
The K?rcher Facebook Team
also:
Where the serial number on the karcher WV window vacuum
Testimonial: "I eventually found the guidance below under FAQ on the Karcher website: "The serial number on the all Kärcher Window Vacuum apart from the WV1 is located behind the water tank. To access this, you will need to: 1. Remove the neck section, by pushing the two black buttons on either side of the suction nozzle. 2. Pull the water tank away from the body. 3. The serial number is located in the first box of numbers. The WV1 serial number is located on the bottom of the machine"."
