Do you mean the alert flag (a triangle with an exclamation inside it) or a different symbol? The Alert flag will appear with another message on the screen. If it is time to replace the battery, you'll also see "BATT" to the left of the flag and a low battery icon somewhere along the top of the LCD screen. If the thermostat is set to alert you to change the HVAC system filter regularly, you'll see "REPL" to the left of the alert flag.
This is from the T4 Pro thermostat manual on pages 6 and 7. See https://forwardthinking.honeywellhome.com/assets/tseries/resources/install/T4%20Pro%20User%20Guide%20-%2033-00188EFS.pdf . The T6 Pro uses the same alert behavior.
I hope this helps.
SOURCE: need wiring for honeywell pro 3000 in trane xe1200
the pro 300 is a single stage thermostat and can not be wired to control 2 heat stages seperately
SOURCE: permanent hold message on thermostat
press run program.... from there, set the schedule for maximum efficiency. permanent hold only shows up after the hold button has been pressed 2-3 times. If this does not fix the issue, there is a master reset button on the thermostat that will set all settings back to factory default.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/cody_17f08cf8e340c06c
SOURCE: I have an old Honeywell thermostat (Chronotherm
you are not geting AC power from the furnace
SOURCE: EEE display code error on CT3600 Honeywell
I am a honeywell dealer and this stat is obsolete and no longer supported. I am not able to pull any info on this. It might be time for a new one.
