Garden Logo
Greg Villa Posted on Nov 17, 2018
My Toro 1800 Power Curve snowblower started but when I released the handle and then tried to restart it wouldn't. Wasn't even snow blowing
I own a Toro 1500 curve electric snowblower. Just this year, a problem has started. The machine will start and run, but after 1 min or so the machine stops. Will not start again until it has warmed up...
It may only need unplugged to reset rather then taking inside.
Likely it's a thermal switch. Try running with out moving snow and see how long it runs.
Jan 18, 2020 • Toro Garden
2016 Toro Power Curve 1800 (electric) - sounds like motor is running, just put a new belt on, but the paddles won't spin. Any suggestions?
The parts diagrams online show some little parts in the drive train, thrust washers and idler/drivers. Are all those parts accounted for and in place? Is the polarity on the motor turning it the proper direction? Hope you can run it with a cover open to see what is happening or not happening. Can you turn the paddles by hand and the motor turns with it?
https://www.partstree.com/parts/toro/snow-blowers-snow-throwers/38025-1800-toro-1800-power-curve-snowthrower-sn-310000001-310999999-2010/housing-and-rotor-assembly/
Feb 06, 2019 • Toro Garden
3helpful
My electric toro power curve 18" snowblower won't start.
Is the plug receptacle you use for your blower a GFI receptacle? If so you may have to reset the GFI as they do blow very easily sometimes. There should be a switch in the plug receptacle in if it is a GFI
You may need to reset it.
I don't know if there is a reset button on your machine or not.
Toro 38451
change the rubbers they are worn out easy
Cannot start Toro 1800 snowblower (electric) inserted key, power connected...
Can you pull start it? If so,you may need a new starter gear,about $30,they're plastic & wear out.
Top Toro Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a Toro Garden Expert? Answer questions, earn points and help others
