Check compressor and fan
SOURCE: Samsung Fridge Freezer (Freezer on top)Model SR-52NXA wont cool
Depends a bit on whether the compressor really is running, or if it's just humming because it's got power on the run coil, but not on the start coil.
Have a careful listen to the compressor. If it's making the trilling or gurgling sounds that go with a working compressor, then your problem is probably one of lost gas. Fixing this is not a do-it-yourself job.
If the compressor sounds like it's stalled, the problem may lie with the starter. Replacements are usually cheap enough for it to be worth fitting a new one just to see if it works.
A.
SOURCE: I have an Amana bottom
If the coils were really dirty, the compressor is probably just overheated. Let it cool down overnight then try again. If it still won't stay running it needs serviced. Could be the start relay or internal overload/overheat sensor in the compressor. If the coils were really dirty and it was used like this for a long time, the compressor could be damaged. It is almost never worth replacing a compressor in a home refrigerator.
SOURCE: fridgedaire side by side fan working, compressor hot, refridgerator and freezer not cooling
.thanks for your question i would try a hard, to start re lay on it after its cooled down. it might just do the trick. the appliance doc
SOURCE: Compressor Fan stop working
Do you have a meter? Either the fan is bad or the capacitor is bad. Ohm out the fan and then the capacitor. Be sure you take the disconnect out of the electrical box on the side of the house and or trip the breaker off. The capacitor is a dual run one side operates the compressor and one side operates the fan. I would really bet on the capacitor being bad. Have seen that a lot in my experience. Be sure to make note of the wiring of the capacitor before you take it out to check and if you are not sure how to check it take it to the parts house and they can check it.
SOURCE: maytag refridgerator model MSD2651HEW refridge not cooling properly
my water dispencer has a low flow after an initial regular flow. why?
