Question about Casio Televison & Video
I have a casio XJ a251. I was turning it off today and my finger had some static and when I went to turn the power button off (dont have a remote) it arched up and hit the button a bit... now I cant get it to turn back on. Anyone have any ideas on what to do or how to fix it? Or is it toast?
    Top Expert:
  • Casio Master
  • 9,900 Answers
Possible RCA universal remote or replacement
Posted on Nov 18, 2018
SOURCE:
techman
  • 3130 Answers
SOURCE: TV auto shut off-power indicator light blinking-won't turn back on
You could have gotten an electrical surge that put your set into a shutdown condition and unplugging the set and letting the Microprocessor reset will fix this problem if it dosent blow out the main power regulator as you still or might I say have a regulator IC problem. IF THIS PROBLEM HAPPENS AGAIN MORE THEN A FEW TIMES WITHIN A SMALL TIME FRAME I WOULD HAVE THE SET LOOKED AT BEFORE THE REGULAOR BLOWS SOMETHING OUT!!!!
Posted on May 14, 2006
SOURCE: tv wont turn on
That same thing just happened to my t.v. The repair person will be here on 10/10/06. I will let you know what they say.
Posted on Sep 27, 2006
  • 68 Answers
SOURCE: No Power
I have read jomuru's solution and agree with him. It is worth unplugging it from the mains for an hour, and then plugging it in, and then trying to switch it on again, as it seems odd that the standby light was flashing originally and then would not do anything. Are you sure the remote control was communicating? Have you tried new batteries in the remote? Are you sure the Power button on the set has not broken?
Posted on Oct 21, 2006
SOURCE: RCA TV stopped working
Time to go to BEST BUY and nuy a better tv
Posted on Apr 16, 2008
SOURCE: Projector won't power up
I don't have a solution BUT the "BEST SOLUTION" of your's dosn't help me at all...
When I put in the cable and press the on/off button (ON) on the back of my Benq, the bottons start to light... But notting happens when i try to push the power button on the top.
NOTTING AT ALL... Any Idea?
Posted on Jul 30, 2008
I HAVE A OLD TASHIBA FLOOR MODEL TV MY ORG REMOTE BROKE HOW DO I TURN TV ON I DONT SEE NO POWER ON /OFF BUTTONS..
Must be buttons or sensors. Just try search with fingers everywhere- behind panel, on the right/left sides.
Apr 25, 2016 | Televison & Video
Why does red TEMP light come on after power up?
The fan is important. If it doesn't turn at the correct speed the red light will come on. Replace the fan and that will fix the problem Go to Casio's website to get the part or try here:
Nov 21, 2015 | Casio XJ-251 WXGA DLP Projector XJ-A251
Projector problem HELP!? my projector was on whiles the utility power went out, and when the power came back i realised it had affected my projector, when i put it on (press the power button) the:...
Kindly get intouch with Cinesonic Audio Visual Pvt. Ltd. in New Delhi at 10/2, DLFIndustrial Area, Shivaji Marg, Moti Nagar,
New Delhi-110015
Contact: ' Board: +91-11-47424444 (30 Lines)'
e-mail: Robert@cavpl.com
For any problem related to Casio Projectors
Mar 21, 2011 | Casio XJ-S31 Projector
Casio xj-s41 lamp and temp light amber blinking
FIRST LOCALIZE THE UP/ DOWN/ LEFT/ RIGHT AND MIDLE BUTON- ON FUNCTION CONTROL
OK...
KEEP PRESSD FOR 10 SEC
INPUT / MIDLE BUTTON FROM FUNCTIONS/ AND RIGHT ARROW
RELEASE THOSE BUTTONS
NOW YOU SHULD GET THE ERROR RESETED.
NOW YOU HAVE TO INITIALIZE THE UNIT:
POWER OFF UNIT( FROM POWER BUTTON)
POWER ON
PRESS AGAIN: INPUT/ MIDLE BUTON/ RIGHT AROW TILL SHOWS A SERVICE MENU ON SCREEN
CHOSE INITIALIZING AND RESEAT UNIT.
GOOD LUCK...GO CANUCKS
Nov 30, 2010 | Casio XJ-S41 SuperSlim DataProjector ...
Static electricity fried the button panel
static electricity can damage the chips on the boards. it all depends were the static voltage went to, if it was just to the buttons controller board or to the main av board. you could need new button board or you could need to replace the main board and the button board its hard to say with static shock.
Jul 11, 2017 | Emerson EWL3706 37 in. LCD Television
I used the PCR-T2000 casio cash register for 3yrs but it suddenly died ,comes on but the keys dont respond.
The standard flag clear should work on this model. Try this first (won't lose data)
Turn key to PROGRAM mode. Turn power off at wall. Hold RECEIPT FEED down - keep your finger on it. Turn power on at wall. Wait 5 seconds, then let go of RECEIPT FEED. You should see "FFFFFFFFFF" on display. Press SUBTOTAL.
Jan 25, 2010 | Casio Parts Cash Register PC Desktop
PROJECTOR PROBLEM Casio XJ 31
it wasn't able to go through cooldown mode. turn it on, power down and let it go through cooldown. does the light come on at all?
May 31, 2009 | Casio XJ-S31 Projector
it wasn't able to go through the cooldown mode. turn it on and power down, letting it go through the cooldown mode. does the lamp come on at all?
Jan 22, 2009 | Casio XJ-S31 Projector
TV automatically turns magic focus mode on when the power button is pressed on the remote and even manually.
I have this problem starting today. Unfortunately, others who have fixed it have done the following.
* Unplug TV for hours and it worked
* Buying manual switch to the outlet or surge protector and switch power off that way.
It appears that I'm in no mood to spend hundreds to get this fixed for hundreds of dollars and just going the Radio Shack route of buying a switch which would probably be more of savings. But needless to say, I hope that is the only problem I have.
Sep 27, 2006 | Hitachi 46F510 46" Projection HDTV
Televison & Video Logo
Top Casio Televison & Video Experts
mikeuk
Steve Allison
Steve Allison
Lawrence Oravetz
Are you a Casio Televison and Video Expert? Answer questions, earn points and help others
