Boating Logo
Ted Schuurmans Posted on Nov 17, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi, The tilt / trim runs very slow up & down after motor made minor impact. Motor is a 1998 Oceanpro V6 225. Your advice is appreciated, Thx Ted
Steve P
Level 3:
  • Johnson Master 3,912 Answers
  • Posted on Nov 12, 2021
Steve P
Johnson Master
Level 3:
Answers
3912
Questions
5
Helped
1306178
Points
15904
With the issue being in both up and down, You may have bent the tilt/trim shaft(s) .. this is a job for a professional!!! sorry..
5 Related Answers
Anonymous
  • 412 Answers
  • Posted on Mar 18, 2009
SOURCE: my comp running slow after overclocking ..
As a general rule, one of the following may be happening:
Loose CPU/Heatink clamp...ie: not tightened enough
If in changing this unit, you unseated your CPU, then clean it off and reseat it again with Artic Silver. Those clamps on this board are hard to get clear down and snapped in properly, so make sure that the CPU is seated clear down in and the heatsink is TIGHTLY clamped in. Oh, being too tight can be as bad as not tight enough, so check that also.
Double check your temps immediately when the thing fires up (look at probe for not only beginning temps, but over a timeline to see what is happening.
Do the same with your power supply with the probe program.
Remove one stick of memory and try it (check manual, because with that board it is NOT dimm 0 or dimm 1 when running one stick)
Make sure you have the Video card seated clear down and have the extra video power plug connected firmly to the video card. If it were mine, I would reseat it.
Make sure your CPU/Heatsink fan is connected properly to the motherboad...same number of pins as your old one, connected the same way.
I would try again to clear the CMOS to see if that helps. I know, you did it, but try it again leaving it open for about ten minutes before you put it back and try it.
Anonymous
  • 3 Answers
  • Posted on May 17, 2009
SOURCE: Volvo-penta aq271c, trim will go down, but not up.no pwr at relay
First check the switch-- does it have power, then check the solenoid to see if it works-- there are two. One is for down, One is for up. If you get power from the solenoid-- outgoing-- check connections going to pump motor.
fordexpert
  • 5692 Answers
  • Posted on Jun 13, 2009
SOURCE: 3 wire tilt/trim installation help
If you have a multimeter which can cost less than $10 or a test light. What you want to do is have the up button pressed and see which 2 wires have power. The 3rd wire should not have power. Then press the down button and see which to wires have power. It should change. Most likely the black is common and feeds power to the switch. When pushed up the blue gets power. When pushed down the green gets power. You may have to provide a ground to the motor from the battery.
Anonymous
  • 86 Answers
  • Posted on Aug 03, 2009
SOURCE: I have a 1994 150 hp Yamaha outboard motor with
Stop! Dont replace the pump...I would bet that it is the "down" Solenoid that went haywire. I would begin by replacing the Down solenoid...it is a far easier and cheaper fix and if your pump works to raise the engine then that tells me that it is not faulty. The Down solenoid looks just like a starter solenoid and the one that you are looking to replace has a GREEN wire to it. Yellow with a red stripe is for the starter. Blue wire is the up solenoid. So replace the one with the green wire going to it and I bet it will fix your problem.
Anonymous
  • Posted on Aug 17, 2009
SOURCE: tilt trim relays just click, when trying to engage
replace 55amper fuse for trim motor
1helpful
When tilting the motor down it jumps and bangs until it gets to the trim pistons, what is causing this?
Power Tilt and Trim Maintenance Makes a Difference ...
yamahaoutboards.com/.../power-tilt-and-trim-maintenance-makes-differe...
Tilt and trim adjust the angle of the motor and thus the running surface of the boat, ...the grip on the water, the ability to jump on plane and many other operations ... be around the base of the ram, or drip down around the power tilt and trim motor. ...Sometimes you can bang on the power tilt and trim motor with the head of a ...
Jan 10, 2016 • Boating
Tilt and trim wont trim up taking off works fine running down the lake
Check trm/tilt release screw,does trim motor run but motor doesn't lift,if trim motor doesn't run then it's probably trim solenoid/relay
Oct 09, 2014 • Boating
How do I replace the motor on a yamaha power tilt and trim 1995
loosen engine mounting bolts and steering tube , trim engine up by releasing the valve on the side and tie up so not tocome down ! remove pin on the ram then remove all bolts and wires and should come out !
We have a 1998 yamaha v4 2 strock 115 engine. we can not get the motor to go down. even if we try to drop it manually
lock lever not down ? does it move up and down at all , the tilt tube could be siezed ,both trim solinoides working ? try standing on the engine gearbox as you trim down or manually release ! if then goes down try injecting the grease nipples with petrol via a grease gun that uses tubes like tooth paste and this will soak the corrosion ! then grease and see if free and if not enough then lift the engine off and remove the tilt tube and clean the sleeves and grease and refit !
Tilt/Trim Motor
check trim switch with multi metre ! check solinoids not stuck !
Jan 16, 2014 • Boating
Tilt trim motor runs by itself
Faulty solenoid,trim switch or shorted wires in control box
4helpful
The trim/tilt on my 97 Johnson 150 outboard is not moving. Tilt motor runs. Some time ago my mechanic told me not to run the tilt all the way to the top, which is, I think, what happened. Any ideas on...
Make sure there is not a spring loaded locking lift latch engauged. If there is you will see a little movement and then the motor will sound slower. If there is no movement and the motor runs the same speed with no change you are low on hydraulic tilt and trim fluid.
Please take a moment and rate my answer............ Thanks
Motor died when I slowed down, and wouldn't crank again
Some motors have limit switches built in to kill the ignition if the motor is started at odd angles. The trim is different for speed and passenger load. The limit switches may be adjustable to eliminate that problem. Usually when you go to dock the boat will fish tail if the trim is too extreme for slow speeds.
Apr 07, 2009 • Boating
Top Johnson Boating Experts
NOEL
NOEL
jws1013
Are you a Johnson Boating Expert? Answer questions, earn points and help others
