Not completely familiar with that exact model but on other ones if there is a jam it wont fire or was jammed and not reset, meaning the driver( what drives the nail) has to be in the up most position. so use a long thin rod and push it back to the top and check that the magazine has nails or that the feed is good. if want to try with no nails you have to leave the magazine open. but should work with charged battery and make sure any adjustment switches are on or off cant be in a middle position. but know from the dewalt framer cordless the driver has to be up before it will fire.
SOURCE: air stapler leaks air through ''nose''
This sounds like one of the O-rings has failed. Yes it can be fixed. Check to see if HD has an O-ring kit for these guns. That kit will contain all of the O-rings as well as the lubricants for a total rebuild. That should resolve your problem.
Dan
SOURCE: Paslode framing nailer intermittent firing
OK lets start from the top, gas full, but what is the expiration date, it is located on the bottom of the fuel cell and if out of date can cause a problem. Second when was the last time the tool was taken apart and completely cleaned and serviced with new orings and lube? Lastly look at the nails are they traveling thru the magazine freely? Let me know and I will try and help further
SOURCE: Nailer jams with 1-5/8 brads
It sound to me that the 1 5/8 brads are not 18 guage but probably 16 guage and they will not work. Double check them first before going any further. You can usually lay them next to the smaller ones that work and see the size difference, if not let me know and I will dig deeper.
SOURCE: Paslode framing nailer 1998 yr. model when engaged wont fire
you have spark and cleaned tool correct, but fan won't turn that freely, if so the fan motor is bad, it should come on when you pull the trigger or move the roller lever for the safety. The fan is about 80.00 Let me know if I missed something and how did you check the spark?
SOURCE: nail gun wont fire
First - the air pressure has to be high enough - check the regulator on the tank to make sure it is delivering in excess of 60-70 psi (which I am sure you have already done).
If you have dry fired these guns (i.e. shot them off with no nails in them while you were lubricating them maybe) the mechanism inside could be damaged. I had that happen to one of my nailers (same brand). That was when I learned not to dry fire them...
Since both of them are not working though I would be more inclined to look at the air supply first.
