Defrosted, no ice on the. Coils. Everything frozen next morning bad temp sensor
SOURCE: Our fridge / freezer is freezing everything,
our fridge is old but is freessing every thingit is on the lowest tempture
SOURCE: Frozen coils on the Refigerator side.
Make sure the evap fan is running,and the coil should covered for propper airflow
SOURCE: refrigerator keeps freezing everything what do i
check the setting in the ref part set on a lower setting if this doesnt take care of the problem replace the thermostat
SOURCE: freezer is not freezing anymore everything is
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong.
If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
SOURCE: freezing in refrigerator but temp
The defrost is not
working,.The evaporator coil in the inner section of freezer is got
blocked by ice . Try manual defrost reset
procedure: ---- First unplug the unit
from main power outlet. Then empty whole unit completely. Then keep both the
doors open. Wait for 24 hours. All the ice collected on the coils and in the
freezer section will get melted. Clean the water from the sections.
Then Connect the power cord of the unit to main power outlet after 24
hours/.Then set the temperature to normal in both fridge and freezer section.
It will take near to 4 hours to get run in its proper cooling cycle. Then check,
if the problem returns again. If the same problem occurs then it's defrost problem.
The defrost board and the defrost thermostat/heater is not functioning properly
and it has to be checked and replaced. -------- Check
the damper if there is too much water collected in
the damper then press the damper and remove the water
collected in it. The procedure of this unit is as follows: --- The compressor
starts then it cools the freezer section. When the freezer reaches its cooling
level the defrost cycle starts functioning. In this cycle the fan in the
freezer section starts running and the cool air in the
freezer section is passed to the refrigerator section and the
refrigerator section gets cold. The air from freezer to refrigerator passes
from the section, in that section the damper is located. If the unit is under warranty then get
this parts replaced by the GE service center. If the warranty is over then you
can get the required parts from online sites like:--- www.repairclinic.com or
from searspartsdirect online site.---------This will help.Thanks.Helpmech.
