SOURCE: head phone jack only plays right side/brad new headphones
Call Philips, get replaced - this is a common problem across all mp3 manufacturers. You can look at the YouTube video on repairing mp3 player headphone jacks, but i doubt it will work without causing more problems with your mp3 player.
SOURCE: on the right side of me JBL headphone doesnt work
You must have broken the cable somewhere. If you move it around you might get it to come on, try it all over to determine where the break is. If very close to the headshell you might want to consider a new cable. If in the middle you can cutt it off before the break and fit a new plug. Then get an extension cable to complete the length.
If at the plug end follow what follows:
Cutt the old ******** and buy a new plug. Cutt it off 10cm before the plug end if the break is the plug section. Most hadphones are fitted with a 3.5mm jack. You will need to solder the wires on. You will find when you have baired back the cable two coloured wires and two earths. The earths fit together on the metal flange that comes out of the main body of the plug. The coloured wires go on the the two smaller flanges (left and right channels). If you get them wrong way round reverse them you won't do any damage. Make certain the earths don't come into contact with the R & L channels wires or terminals and the left or right don't touch each other. The T shaped end on the large flange is to grip the cable body, bend the tabs to grip the cable.
SOURCE: the right headphones just stopped
Well i first would try another set to make sure it is the new set. If it still is the new set at fault? If you still have the receipt? Return it. If not? Check the plug and while its on and you have a cd playing/or radio whichever. Wiggle the plug . Take it out and slowly put it back in if you hear the bad side come on? Clean the new plug with alcohol. If no change? Factory error might have not soldered that side correctly. Take the effected side apart and look at the solder joints. If a wire is off? Resolder it on.
Hope this helps. if wires are still on the speaker ? Resolder them any way. Sometimes just heating and melting the existing solder works fine.
Hope this helps.
SOURCE: Do headphones NOT work in these speakers or do
Bluetooth Headphones V3.0 Handsfree Stereo Wireless Headset with Microphone earbuds for Apple and Samsung LG Amazon com Charm sonic Bluetooth Headphones V3 0 Handsfree Stereo Wireless...
