Question about Sanyo Televison & Video
My Sanyo TV is stuck om Photos and underneath it says Change Directory and under that USB. It won't respond to my remote at all. Help, please
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 98 Answers
The onlything to do is to locate the MEMORY IC and reball it or replace
Posted on Nov 16, 2018
SOURCE:
SOURCE: sanyo stuck on video mode
Yippie, I figured out a solution that worked!!! I have a univeral remote from comcast, on that remote near the bottom left is a small button that says (input) tv/vcr, press that one time and whala!! the tv video screen was gone, I had to manually change the channel from the tv channel button on the unit. once I changed the channel to 3, my universal remote worked... the button is the second one from the bottom left... I was on hold with sanyo for a long time and just kept trying on my own, so good luck!!!!
Posted on Mar 01, 2008
SOURCE: Sanyo TV stuck on video channel
sanyo ds35590 no remote, tried universial remote still cannot select menu on uvm. What remote do I need? Or can I get into the menu without remote. I am trying to watch a dvd.
Posted on May 25, 2008
SOURCE: Universal remote codes
I need some codes for my sanyo T.V.
Posted on Oct 12, 2008
SOURCE: TV stuck on Video
I had this problem, I replaced the remote and it works now
Posted on Nov 03, 2009
  • 382 Answers
SOURCE: tv not responding to remote
This may sound silly but does the remote have a funtion button or buttons at the top of the remote? It may be set to operate a DVD or VCR instead of the TV.
Failing that check the batteries, it is very rate that your TV will stop accepting IR signals.
Hope this helps,
Cheers
Posted on Jan 06, 2010
Tv is stuck on Video 1 and the remote is missing.Won't respond to the cable remote except on and off. HELP
Try pressing tv first on your cable remote then the video/source/input button on the cable remote. If there is no button on the television itself to switch video inputs a temporary fix for now is to connect the cable box to the video 1 female parts on your television. Buy the cables to do that if you don't have a spare set lying around. You can purchase a remote for your television with the model number from http://www.replacementremotes.com or even a Sanyo remote from a thrift store should be able to allow you to switch inputs.
Aug 21, 2011 | Sanyo Televison & Video
NEED THE CODE TO PROGRAM MY SANYO GXDB REMOTE
How can I reset my Sanyo GXDB remote?
It worked at first, then the channel up down buttons were not responding. Now the entire remote isn't responding or lighting up. It's as if the whole thing is blocked.
Yes I tried new batteries etc. I just bought the tv with remoteon Saturday. Please help as the guys at sanyo are useless!!!
Dec 29, 2009 | Sanyo Televison & Video
Re-activating universal remote control cable, DVD, VCR
Hello Trublugrl,
This should help you out.
Here are the codes for Sanyo 017,021,039,056,057,058
Press and "HOLD" CODE SEARCH.
Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
Enter the three digit code from the TV, VCR or Cable Box code listed above.
Release CODE SEARCH.
With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps using another code number from the list
I hope this Helps you out, If this does then Please leavea a thumbs up.
Cheers Little Dish Fitter
Oct 26, 2009 | RCA Universal Remote Control
TV is stuck on video 1?
You probably have a replacement remote. It will need to be reprogramed to your tv. You should have instructions that you got with the remot. Otherwise call your TV repair man and he can probably "walk" you through it over the phone.
Jan 12, 2009 | Sanyo DS32224 TV
Power plus universal remote control codes
Try downloading this manual
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/mitsubishi/bd512-manual.zip&area=other
Jul 13, 2008 | Televison & Video
Remote to TV problem
i can suggest to chek if the remote that you buy is corrct for your tv,d
maybe it is not what needs it -- you can try to change it where you
buy it with another one -delfo
Mar 20, 2008 | Sanyo DS27930 27" TV
Jan 17, 2008 | Televison & Video
Sanyo stuck on video mode
Jan 13, 2008 | Sanyo DS27510 27" TV
ok i have a sanyo tv that was set to imput my remote messed up but now it is fixed i cant figure out how to get it off. in order for me to reprogram my Universal remote i have it has to scan channles right wut do i do??? plzzz help me!
Dec 30, 2007 | Sanyo AVM-3259S TV
Sanyo DS27910 27" TV
Sounds like either there's no connection to an antennea or your tuner is dead. Our TV has the same problem, so we took out the tuner and the games and dvd plays good still. So it's probably the tuner.
May 01, 2007 | Sanyo DS27910 27" TV
Televison & Video Logo
29 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
