SOURCE: dishwasher not working
The motor may be burned out or there may be another electrical issue which would also cause the symptoms you describe. Call around and try to get an estimate, and at the same time look at new ones on sale.............one question is how secure will u feel with that maching......now that it has acted up like this.
SOURCE: My washingmachine stopped working and gave off
Had one similar to this about three years ago. That burning smell would be the belt that runs the washer. Relatively easy to repair. You'll need make and model number to get the right replacement belt. Once you have it, get up under it, remove the old belt and put the new one on the same way. The belt will go around the pulley on the bottom of the washer drum, the motor and the tensioner. This should solve your problem. If you need more help, please let me know.
SOURCE: Bosch Dishwasher Classix
I've had the same problem TWICE. It seems the natural vibration of the machine loosens wire nuts and leads to the problem. Soldering the connection and then placing a yellow wire nut over the soldered connection works fine to stop the problem. This machine has a electric water heater to sterilize the dishes and draws a lot of power, near the limit of the connection, more than a standard dishwasher. I called Bosch twice about this problem, only the second time when I stated that my lawyer might call them back did they admit that there is an issue with the vibration of the machine leading to the wire nut becoming loose and suggested I solder the connection. Great dishwasher, lousy customer service. They have know about this problem for years.
SOURCE: Laser guide on Bosch 4410L miter saw is off.Can it
I looked thru their onwers manual and the parts breakdown and find no reference to adjusting the laser. I would recommend calling them direct at 1-877-267-2499 for assistance. I wish I have better information but this is all I can find. Good Luck
SOURCE: kenmore vacuum model 116.3592250 works fine, burn smell
is that the one with the direct drive brushroll? those brushroll motors inside the brushroll always go bad. that is one of the worst designs from kenmore. is the brushroll turning?
