J
Jorge Legra Posted on Nov 16, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is the cause of rattling from a catalytic Converter on a 2001 Jaguar SType?
Can it be fixed?
Kardoc
Level 3:
Top Expert:
  • Jaguar Master 7,501 Answers
  • Posted on Nov 16, 2018
Kardoc
Jaguar Master
Level 3:
Top Expert:
Answers
7501
Questions
0
Helped
2755248
Points
58317
It could be the heat shield which is external which can be repaired or the catalyst inside the converter may have broken, which means that it must be replaced.
5 Related Answers
dennymulford
Dennis Mulford
  • 1055 Answers
  • Posted on May 21, 2009
SOURCE: heat shield rattles
yes you can remove it or put a couple of tac welds on it!!
Anonymous
  • 133 Answers
  • Posted on May 28, 2009
SOURCE: Replace muffler, not the catalytic converter which started to rattle. Stop running, will crank but will not start. can it be the catalytic converter.
if the converter is rattlin then it needs to be replaced because the element inside is broken. if the jeep still does not run try removing the catalytic converter to see if the restriction is too much. should start if the converter is restricted. if it doesnt maybe its whatever caused the converter to go bad in the first place
Anonymous
  • 1959 Answers
  • Posted on Jun 01, 2009
SOURCE: do I need a catalytic converter
Yes but there could be other causes. A sticky fuel injector, bad fuel pump etc. Other signs of a bad catalytic converter are a smelly sulphur exhaust, a very hot exhaust throwing heat from the middle of the car. Unless there's a lot of miles on your car, I'd be surprised if it were a bad Cat. Hope this answers your question. Best of luck.
Greg
FtheT
  • 22 Answers
  • Posted on Jun 19, 2009
SOURCE: my subaru forester has a rattle in the catalytic
I bet its just a the heat shield on the catalytic converter. Subaru uses very thin metal and the heat shield is bolted as opposed to welded together. This rattle is extremely common on subys.
mrmopar is right that you should replace it.
however there is a quick fix that will stop the noise. Go pick up a 6" stainless steel hose clamp at the hardware store. put the hose clamp around the cat. It should be obvious whats loose when you look under the car.
if you are a little handy its not a hard job to do your self. Just 4 bolts. You can get a catalytic converter for $200 online. Get the gaskets too. shouldn't take more than an hour or two.
You will need to put the car on jack stands or rhino ramps to get access. Once you are under the car, the parts are easy to get to.
Always, always chock the tires when your under the car. You do not want a car to fall on you.
raygin
Raygin
  • 322 Answers
  • Posted on Mar 09, 2010
SOURCE: I have a 2001 Jaguar S Type 3.0l that had a P0430
PO430 = Catalyst System Efficiency Below Threshold (Bank 2) You may still have a sensor fault in the combustion/injection system, You need to get this checked at a garage with the correct monitoring system for while the engine is running. Or take a gamble and change sensors. Hope this helps - good luck.
Catalytic converter replaced still experience popping noise in exhaust in second gear when acceleration failure codes found on all four o2sensors and purge control circuit also hear debris rattling i
there is unburnt fuel entering the exhaust system caused by abnormal combustion chamber condition on one or more cylinders. Check for air leaks using a smoke machine and replace plugs and leads.
Rattling catalytic converter 2001 s500
Once your catalytic converter starts rattling that means it has to be changed Not cheap either.
1helpful
Removing catalytic converter in 2001 buick lasebre
I didn't know Texas was exempt from federal law? Federal emissions law requires the vehicles tailpipe emissions system to be intact and in working order in order for the vehicle to be licensed for on road use. If the catalytic converter was removed and you didn't tell the buyer, the buyer can hold you responsible for all costs to repair the catalytic converter. Removing the cat will also cause a never ending check engine light do to the wrong downstream O2 sensor readings. You are better off replacing the catalytic converter with either an o.e. or a quality aftermarket unit.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
What causes rattling under the truck on a 2001 ford expedition only when driving
More than likely the Catalytic Converter ceramic brick is broken up and rattling around inside the cats metal shell, it is really annoying.
2001jaguar 3.0 stype code p0420 and p0430
You may need a shop to look at this.
Code 420 is saying the catalytic converter is not working well on bank one and code 430 is the same thing for bank two.
There is an O2 sensor in front and behind each cat. The computer uses the readings from the front and back sensors to judge the performance of the catalytic converters.
Since it would be very rare for both cats to fail at the same time, chances are the problem is a vac leak or injector problems with the engine. I would say something wrong is happening before the exhaust gets to the catalytic converters.
Rattling noise
Check catalytic converter.Catalytic converter could be breaking up inside.
5helpful
Getting OBD codes p0420 and p0430, how to fix these issue with my 2001 Audi A6
2001 Audi A6
EOBD code: P0420
Fault location: Catalytic converter system, bank 1 - efficiency below threshold
Probable cause: Catalytic converter, wiring, heated oxygen sensor 2 (downstream)
EOBD code: P0430
Fault location: Catalytic converter system, bank 2 - efficiency below threshold
2helpful
Which is what I do to write the code P0420, as do I fix it? I change it?
So what is causing my P0420 code? There are a number of things that could be causing this p0420 catalyst efficiency code. The most common thing is the catalytic converter itself is no longer functioning properly. The other likely thing is the rear O2 (oxygen) sensor is no longer working properly. Other things could include exhaust leaks, damaged exhaust pipes, damaged O2 sensor wiring/connectors, plugged catalytic converter, etc.
OK, so I want to diagnose things, what do I do next? The easiest thing to do first is a visual check of things. Visually inspect the exhaust system for leaks, check the catalytic converter for dents, holes, severe discoloration, and check for a rattle inside. If any of those syptoms are there, the converter likely needs replacement. Then, visually inspect the downstream O2 sensor (behind the converter). Check for broken wires, obvious faults, etc. If all that checks out, you'll want to check the operation of the O2 sensor. To do that, you'll need access to a scan tool or oscilliscope. Check that the waveform is pretty steady. If the reading fluctuates then the sensor is likely bad and will need to be replaced.
On some vehicles such as some Subaru models an ECM reflash will fix the problem. As you can see a P0420 can be caused by many things, so if you have any doubts as to whether you can fix the problem yourself, please seek the advice of a professional technician. Good luck!
Answer found @ www.p0420.com
2helpful
14helpful
4answers
My subaru forester has a rattle in the catalytic converter can it be repaired
Top Jaguar Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Jaguar Office Equipment and Supply Expert? Answer questions, earn points and help others
