Which model do you have? On the H12 and 696 series models, F indicates refill the humidifier; the reservoir bottle is out of water. The CF means check the filter/wick. Replace the wick if appropriate. The CF message will appear every 720 hours of run time for the humidifier. It will be reset when the unit is unplugged or loses power.
You can find the Owner's manual for many of the Aircare humidifiers on the product page. Start at https://aircareproducts.com/ Then look for your humidifier. The link to the owner's manual is just below the Add to Cart button on the right side of the page. Use the manual to identify the correct filter or wick for your humidifier.
I hope this helps.
SOURCE: i have lost my manual. readout on the digital
It means Change Filter.
However, assuming that you have done that in the recent past, you probably want to know more. I'm not sure how this actually works (that is why it shows CF). I saw it for the first time after 2 or 3 years of using my humidifier. (And I had just changed the filter a week or so previously).
You may have to turn the unit off/on or even unplug it to clear the message, then it should operate normally.
